Author Topic: Gearbox Problems  (Read 2423 times)
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
Gearbox Problems
« on: 26 July 2012, 09:33:39 »
Ok, finally got around to putting the the original radio & cd player in (CCR600 changed from a CAR400) and struggling to run all the wires etc through. Problem now is that I seem to have done something to the garbox in the process as all was fine before I started.
There are now no selector lights lighting up and MID shows the dreaded "Automatic Gearbox"
The question is, have I Just managed to blow a fuse for the box ecu or is there any gearbox related plugs behind the radio that I may have disconnected? Something simple like that? or is this something that has just decide to go wrong at this time?
Selector lights not lighting up suggest to me a fuse or conection but I am no expert!
Please help!
Nick
Daily drive     - 1997 2.5 CD Auto - 25-35 mpg
Weekend Fun - 2003 RX8 231      - 14-18 mpg
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Gearbox Problems
« Reply #1 on: 26 July 2012, 14:11:16 »
you may have pulled the wire out when doing the radio, think if you take of the gear selector should see the plug, but may be wrong.
Solar charger fitted.
If not Broke dont fix it..
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
« Reply #2 on: 31 July 2012, 11:09:55 »
Update:
Well tried disconnecting battery overnight to reset everything - no joy
Tried wiggling wires checking pugs on Gearbox ECU - no joy
Pulled all fuses to check for blown ones - all fuses ok - now gaerbox selector lights on and all is working fine again!!!???
Completely confused me, but not going to complain as all working again now!
