Author Topic: New car... a few niggles  (Read 4532 times)
bruceybonus
  • London
    • 3.2 Elite
« on: 27 July 2012, 17:03:34 »
So 2 weeks ago I bought my 3.2 elite... all good I though and on the whole it is...
So far I've had the following occur....
1. parking sensors dont appear to have any life in them ( I'm a big boy so can park fine anyway, but would be nice to have them working, but nor sure where to start to find the fault.. )
2. Ive had the spanner light come on, then go off, then come on again then go off... quite a few times during a 500 mile round trip back up north
3. drove it for about 5 mins the other day.. all ok .. turned it off then it wouldnt start... so had to leave it by the side of the road for a day.. came back and it fired up fine.... took it to my m8s garage and connected the old solus and low and behold.. no codes registered...
so . err any ideas? cause i'm getting a bit stumped especially about the starting thing....
2001 3.2 Elite, leather NCDC 2015 with CID
Re: New car... a few niggles
« Reply #1 on: 27 July 2012, 17:31:57 »
Pedal trick for codes may find an 0335
http://www.omegaowners.com/forum/index.php?topic=90581.0
« Reply #2 on: 27 July 2012, 23:49:34 »
Yep sounds like classic crank sensor failure.  If a new one fitted make sure its genuine Vx ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 27 July 2012, 23:55:14 »
Might just be the speaker?
bruceybonus
  • London
    • 3.2 Elite
« Reply #4 on: 01 August 2012, 12:37:27 »
Yeah I was thinking crank sensor... seems the best option.... just like the dreaded egr on my previous signum!
however..it doesn't cut out whilst running..........
does anyone in the london area have a tech2 or "My Naff Code Reader"?
« Reply #5 on: 01 August 2012, 15:22:10 »
I have a Tech 2 (see link at the bottom of this post). The closest that I regularly come to London is J4a of the M3 though. Try the pedal trick first, though. Might save you a journey.
bruceybonus
  • London
    • 3.2 Elite
« Reply #6 on: 02 August 2012, 17:10:29 »
Ill give the pedal trick a go.... the spanner light is currently on, but keeps going off then on and them off again... the car hasn't failed whilst driving yet though.... only when it was switched off then it wouldnt start again for about a day! but thats only happened once so far..
bruceybonus
  • London
    • 3.2 Elite
« Reply #7 on: 02 August 2012, 17:14:02 »
I'm going need to get hold of the car pass as well.. does anyone know any reliable vx dealers around kingston that won't rip me off getting one?
« Reply #8 on: 02 August 2012, 17:37:30 »
Suggest as soon as, if it`s an 0335 code and the crank sensor gives up you`ll never start it
bruceybonus
  • London
    • 3.2 Elite
« Reply #9 on: 03 August 2012, 16:43:43 »
Cheers Rob, I'll give it a got and post up....
bruceybonus
  • London
    • 3.2 Elite
« Reply #10 on: 04 August 2012, 10:37:26 »
ok so after pedal code.. getting 0325.. which one is this?
« Reply #11 on: 04 August 2012, 10:54:54 »
http://www.omegaowners.com/forum/index.php?topic=90594.0  :y
knock sensor 1  ;)
« Reply #12 on: 04 August 2012, 10:56:41 »
Bank 1 knock sensor.
Favourite here is that the wire has been trapped under the aux. belt tensioner pulley bracket during a cam belt change.
Worth double checking it's not 0335 though. ;)
bruceybonus
  • London
    • 3.2 Elite
« Reply #13 on: 05 August 2012, 08:49:36 »
yes sounds possible as the cambelt has just been done!
« Reply #14 on: 05 August 2012, 08:58:39 »
Worth checking it's been plugged back in, though. Connector just at the driver's side of the cable tray that runs across the front of the cam belt cover. Follow the wire down and see if it's trapped under the pulley bracket.
