Downside of manual conversion...
Started by JamesV6CDX, 27 July 2012, 23:54:51
Here is the downside of manual converting...
My revs seem VERY high when cruising at motorway speeds in 5th.
If you want to make good progress, the economy is non existant on the motorway :(
Anything I could do with the Diff to improve this?  :-\
Quote from: JamesV6CDX on 27 July 2012, 23:54:51......
Aren't the diff ratios different between auto & manual ......  :-\ :-\ :-\
Quote from: Andy B on 27 July 2012, 23:59:47
I was under the impression the manual diff would make it rev even higher, I may be wrong....
The only other point to note, is that I have some play, somewhere. Can't work out if it's box, or DMF
Most noticable at higher speeds, if you let off the gas at say, 70mph, a couple of seconds later it feels like some slack is taken up, and there is a little "tug" in the drivetrain. Then when you re-apply the gas, there is a another jerk, as the drive is taken up again..  :-\
Now the novelty has worn off, I am finding myself getting cross with the manual box a little more often... it has a long throw, and to get a smooth gearchange you do have to take a little time, which loses lots of power... I reckon realistically, I could get away easier in the auto, even though it is a beast in manual form...  :-\
serek
maybe you drive to fast ;D ;D ??
btw if you get diff of early 3.0 manual then your revs will drop down by 300rpm at 5th gear
what sort of rpm you have at 70 on 5th gear at the moment??
tidla
I thought you was going to say you cant eat a bigmac while driving. ;D
Quote from: serek on 28 July 2012, 00:04:28
Possibly Serek!
At 80mph, it's sat half way between 3000 and 3500 rpm...
Quote from: JamesV6CDX on 28 July 2012, 00:06:49....
3250 rpm ......................  ::) ::) ::)
Quote from: JamesV6CDX on 28 July 2012, 00:03:46......
As said many times  ::) ::) ::) why have more pedals than feet?  ::) ;D ;D ;D ;D ;D
Quote from: Andy B on 28 July 2012, 00:09:11
Yes, that.  ::)
serek
Quote from: JamesV6CDX on 28 July 2012, 00:10:30
Yes, that.  ::)
thats about right for 3.2 manual with 3.9 diff
if you want get few more MPG then go for 3.7 but wont be lot differents I try this before
As serek says,  3.7:1 is they way to go. According to Mr Haynes it seems that the manuals are all 3.7.
3.7 ???
you will loose acceleration ..
you will get used to it.. but if you really want a short shift ,  you need a sports tranny and lots of work :-\
Quote from: cem on 28 July 2012, 07:30:46
3.7 ???
Pish :P
My ex plod 3.2 manual, running its original gearbox and 3.7 LSD will pull 0-60 in sub 7seconds, even with a slight misfire and 225k 8)
Wheel size will make a slight difference to the cruising revs. Bear in mind that the MV6 and Elite wheels with 235/45/17 tyres have a smaller roling radius than the 225/55/16s, meaning they'll be spinning faster at any given speed :y
If mine was doing 3250 rpm at 80 I'd be wondering if the clutch was on it's way south ::)
Swap the diff if it's that big a deal  :y
Gear changes can be done fairly swiftly, just don't rush between 2nd and 3rd, as that will really wind it up.
