So guess where the MIG keys are!
Started by zirk, 05 August 2012, 13:24:20
Quote from: Lazydocker on 05 August 2012, 14:13:01
Quote from: zirk on 05 August 2012, 14:09:06
Quote from: Lazydocker on 05 August 2012, 14:04:14
Through the rear seats ;)
Cars deadlocked LD, really dont want to do a window, because Im not convinced I can get to the Manual pull with a LPG tank in the way?, also not sure if the release button works with the car locked up?
How big's the tank? As for deadlocked... There is a solution but I don't know it and it's not something that should be shared (publicly) online ;) If you get really stuck I have a set of Jigglers and might be able to get down to you during the week :-\
So weve heard. :P ;D ;D
Pfl stops nobody walking up to the unlocked boot and helping themselves while your in it at the lights. Which can't happen in the superior face lift. :)
Quote from: chrisgixer on 05 August 2012, 15:00:12
You just put the key in the lock & turn it ........  ;) vertical = opens & closes with central locking, horizontal - always locked  ::) ::)
Quote from: Andy B on 05 August 2012, 14:54:37
Quote from: TheBoy on 05 August 2012, 14:48:38
Quote from: Andy B on 05 August 2012, 14:43:20
Quote from: TheBoy on 05 August 2012, 14:39:35.....
Stupid inferior facelift design.
I suspect though, there are loads of cars out there that you can easily do the same thing with. Both SWMBO's Smart & my 'new' R Class will both open their boot/tailgate without unlocking the rest of the car, you then put the key down while you load/unload your car, shut the boot and then ask on a forum how to get into the car when your only key is locked inside!  ::) ;D ;D ;D
I rest my case.
Makes the superior PFL design so much better, if less profitable for the dealers
Just make sure your 'new' car comes with two keys ........ like we didn't with her Smart - £190 for the privilege a new one!  >:( >:(
First thing I do is sort out a spare key, on any car.  Which reminds me, I need to order a new spare for the bike. Again.
Even Golden Nugget had a spare key sorted out for it, even though I only had it about 6 weeks ::)
Quote from: TheBoy on 05 August 2012, 15:03:14.....
First thing I do is sort out a spare key, on any car.   ......
hence the £190 for another Smart key, SWMBO can never find the same key twice!  ::) ::)
zirk
Just had a quick butchers at another Saloon, hmmm, plan F coming up. ;)
zirk
zirk
:y :y :y :y
Boot now open, said Key in hand, no broken glass!!
and so easy, too easy in fact!!!
zirk
The way the Olympic Red Lights are set at the moment, I reckon I can now get into a FL Boot in that time.
:D
Quote from: zirk on 05 August 2012, 15:42:56
:y :y :y :y
How?
Paddy Flannery
Zirk,
Trying to PM you, but inbox full.
zirk
zirk
Quote from: RobG on 05 August 2012, 17:19:14
:y :y :y :y
How?
Popped the Boot Rob.  ;)
Paddy Flannery
