Author Topic: So guess where the MIG keys are!  (Read 7655 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 05 August 2012, 13:24:20 »
Dangle Bloody Berries, cant believe Ive just done that!
Remind me please, easiest way to get in the Boot, without a spare key!
Re: So guess where the MIG keys are!
« Reply #1 on: 05 August 2012, 14:04:14 »
Through the rear seats ;)
zirk
  • Epping Forest
« Reply #2 on: 05 August 2012, 14:09:06 »
Cars deadlocked LD, really dont want to do a window, because Im not convinced I can get to the Manual pull with a LPG tank in the way?, also not sure if the release button works with the car locked up?
« Reply #3 on: 05 August 2012, 14:13:01 »
How big's the tank? As for deadlocked... There is a solution but I don't know it and it's not something that should be shared (publicly) online ;) If you get really stuck I have a set of Jigglers and might be able to get down to you during the week :-\
zirk
  • Epping Forest
« Reply #4 on: 05 August 2012, 14:19:11 »
Thanks LD, on plan E at the moment, thinking out load, I can get the Bonnet up, assuming the Boot Release works with the Car locked, Im guessing the switch wires, either as a pair (or one goes to ground or 12v) goes to the ECU, so can someone tell me the wire colours or ECU pin out maybe? or PM me the info.
Thanks
zirk
  • Epping Forest
« Reply #5 on: 05 August 2012, 14:22:16 »
How big's the tank?
Not sure, guessing 80 or 90, but around £62 to fill from empty.
« Reply #6 on: 05 August 2012, 14:25:05 »
How big's the tank?
Ahh... That makes it too big to get past. The 80L tanks we recommend do (we think) leave enough room to get the release (just) :-\
With access to the engine bay, even if you just fire the central locking it's a start ;)
zirk
  • Epping Forest
« Reply #7 on: 05 August 2012, 14:27:39 »
How big's the tank?
May need a bit more info on that ;)
« Reply #8 on: 05 August 2012, 14:33:59 »
JamesV6CDX knows how to access the boot
http://www.omegaowners.com/forum/index.php?topic=103625.0
« Reply #9 on: 05 August 2012, 14:39:35 »
Thanks
ECU is in cabin, so no help ;)
If deadlocked, I'm guessing window :(
Stupid inferior facelift design.
« Reply #10 on: 05 August 2012, 14:43:20 »
I suspect though, there are loads of cars out there that you can easily do the same thing with. Both SWMBO's Smart & my 'new' R Class will both open their boot/tailgate without unlocking the rest of the car, you then put the key down while you load/unload your car, shut the boot and then ask on a forum how to get into the car when your only key is locked inside!  ::) ;D ;D ;D
zirk
  • Epping Forest
« Reply #11 on: 05 August 2012, 14:45:26 »
Thanks Rob, James is off line at the mo, plus I need the Car for tomorrow if you know what I mean.
zirk
  • Epping Forest
« Reply #12 on: 05 August 2012, 14:48:08 »
Thanks
Thanks for that, bugger, off to get another Saloon so I can have a play, will be back in 15.
« Reply #13 on: 05 August 2012, 14:48:38 »
I rest my case.
Makes the superior PFL design so much better, if less profitable for the dealers
« Reply #14 on: 05 August 2012, 14:54:37 »
I rest my case.
Just make sure your 'new' car comes with two keys ........ like we didn't with her Smart - £190 for the privilege a new one!  >:( >:(
Page created in 0.268 seconds with 20 queries.
