Author Topic: Boiler  (Read 1519 times)
Boiler
« on: 05 August 2012, 20:11:35 »
Boiler fan stopped electric fault , i took the front cover off and it was red hot from the pilot light  ::) Quickly turned the gas off . Big thanks to martin42 on here for giving me some info on fault finding ...ive traced what seems to be the internal 2A fuse that has blown ....thing is though why  :-\ going to replace the fuse tomorrow and see what happens , could the lightning storms we had today have caused this  :-\ It was ok this morning when we used the hot water then we went out , come back and no electric on the boiler at all  ???
martin42
Re: Boiler
« Reply #1 on: 05 August 2012, 20:23:44 »
fan might be jammed up or a fault on the circuit board,but it could be ok tho once fuse is replaced
Re: Boiler
« Reply #2 on: 05 August 2012, 20:37:29 »
Hope so or we will be washing in the tin tub filled with warm water from the kettle  :( :y
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
Re: Boiler
« Reply #3 on: 05 August 2012, 21:01:21 »
just in case get the wife to turn it on :y :y
Re: Boiler
« Reply #4 on: 05 August 2012, 21:16:48 »
She's not happy ... came down the stairs after getting a cold shower  :(
Re: Boiler
« Reply #5 on: 05 August 2012, 22:25:34 »
Bearings in the fan often dry out and sieze up. Worth checking if it'll spin freely, although that wouldn't cause the fuse to fail, IMHO.
the alarming man
  • medway kent
    • disco V8
Re: Boiler
« Reply #6 on: 05 August 2012, 22:38:02 »
depends what type of fan it is as was told the fans fitted too baxi boilers are the worst you can only expect to get 3-4 years out of them but fuses can just blow...they get what a sparky called it the other day...tired.... :y
Re: Boiler
« Reply #7 on: 06 August 2012, 08:11:04 »
It spins freely kevin and no funny electrical burning smell either .... fuse was all black when i took it out  :(
Its not a baxi its an Alpha 280  :) Hoping it is the fuse .... wont know till i get back this afternoon after my  2nd MRI scan  ;)
kully
  • England
    • 2.2 DTI CDX Saloon
Re: Boiler
« Reply #8 on: 06 August 2012, 08:20:54 »
I nursed an unloved Alpha through seven years at my last house. I swore at it a lot (especially when the hot water goes in the middle of winter), and it did need messing about with every year.
However, if you ring up Alpha, you will get to speak to someone in this country, who knows what they are talking about and will probably have heard your exact scenario before, or at the least will be friendly and helpful - 01732 783 000 - I rang them enough times :-)
Re: Boiler
« Reply #9 on: 06 August 2012, 08:32:23 »
Thanks for that kully , number written down and will give them a ring if the fuse dont fix it  :y
Re: Boiler
« Reply #10 on: 06 August 2012, 14:53:26 »
Pack of ten 2A fast blow fuses ...popped one in , power back onto the main panel and the fan is working a treat  :) :) :) gave it a good hoovering out . Thanks martin for pointing me in the right direction .... just need to service the car now  ::)
Mystery how it blew though ...maybe a power surge .
