Author Topic: Changing rear springs question  (Read 1725 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 06 August 2012, 12:51:27 »
Half way threw the job.
Bottom shocker bolts are out but I can't seen to get them to seperate   >:(
Is it just a case of beating the cr*p out of them to get them to part or is there a simple way ?
Re: Changing rear springs question
« Reply #1 on: 06 August 2012, 12:54:35 »
Something like that ;D
« Reply #2 on: 06 August 2012, 13:07:30 »
They are a sort of press fit. So brute force needed. I usually put the bolt back in only as deep as the end of the shock spacer and use that as leverage by hand or tap firmly but GENTLY with a hammer to lever the bugger out. :)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 06 August 2012, 13:17:51 »
Ok, thanks lads   :y
I'll have a play and see what happens but tbh, I may drop them from the top  :-\
My axle stands are crap and I don't want to spent too much time under there  ;)
« Reply #4 on: 06 August 2012, 13:46:32 »
Is it an Estate?
Saloon ones tend to just drop out, Estate ones are slightly angled I think and can be a right pig!
I managed to separate the shock from its rubber bush  ;D ;D
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #5 on: 06 August 2012, 15:03:10 »
Is it an Estate?
When we changed the springs on my estate we (mistakenly in hindsight) pulled the shocks off the rubber bushes because we couldn't separate them from the arms, then we had a pig of a job to get the shocks back over the rubber bushes
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 06 August 2012, 17:13:18 »
Jobs a good un
Makes one hell of a difference  :y
Thanks for the advise lads  :-*
