Author Topic: Thank you Kevin Wood, again.  (Read 2217 times)
« on: 17 August 2012, 00:06:56 »
...and Mrs Wood. Took up most of their evening with Kev tech2 ing my car and checking the gas.
Plus some pondering over my stiff pas issue. It's always a pleasure talking cars, or anything, especially anything technical with Kev.
I wish my brain worked as well as his.  :-[
Thanks for your time Kev. Much appreciated.  :)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Thank you Kevin Wood, again.
« Reply #1 on: 17 August 2012, 09:20:52 »
X2 -  :y :y
« Reply #2 on: 17 August 2012, 09:42:44 »
It was a pleasure. :y
You speak too soon. :-[ Meant to check my PAS system when I got to work to see if my PAS reservoir also resembles a deep fat fryer after a little drive, but was in autopilot. ::)
« Reply #3 on: 17 August 2012, 10:22:33 »
Bah, that's nothing. My autopilot is so engrained, when driving anywhere near my old commute across Reading, I will almost certainly end up at my old work!( or at the very least try to drive that route at some point in the journey) Regardless of my actual destination in Reading itself. ;D
I have worked in Slough for the last 7 years. ;D
:-[ ;D
« Reply #4 on: 17 August 2012, 10:43:38 »
:-[ ;D
That's force of habit... I nearly ended up in Felixstowe last week :-[ ::)
« Reply #5 on: 17 August 2012, 10:44:58 »
All you old fellas with failing memories. I shouldnt mock.I suppose I will reach that stage some day. ::) :D ;D
« Reply #6 on: 17 August 2012, 13:46:23 »
.. if the Albsheimers doesn't mask the symptoms. ;)
« Reply #7 on: 17 August 2012, 14:19:09 »
Yeah, I'm with you Mr Albitz...
...only I've lost my carkeys, and I will need them in about 4 hours....  :-[
« Reply #8 on: 17 August 2012, 21:33:45 »
Have you tried you bike :-\ the keys are probably all there ::)
Unless you've locked them in the boot of course ::)
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
« Reply #9 on: 18 August 2012, 00:25:42 »
:-[ ;D
i  ended up and wung hung lows massage parlour but wifey was not happy about having to wait in the car :o :o
« Reply #10 on: 18 August 2012, 10:21:47 »
Found. In the ignition.
« Reply #11 on: 18 August 2012, 12:16:47 »
;D oh I must be doing ok then, I've not done that yet ;D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #12 on: 18 August 2012, 15:53:31 »
Aye he's a good egg is Kev and very generous with his time and considerable brain  :y
