Author Topic: Radiator Fans Not Working  (Read 1961 times)
nordic
  • Sunderland
« on: 17 August 2012, 15:00:08 »
Hi,
Sadly, my twin radiator fans have suddenly stopped working! :'(
Where should I look to solve the problem? :-\
Cheers
Andy
Re: Radiator Fans Not Working
« Reply #1 on: 17 August 2012, 15:02:43 »
fuses in the triangular box by the battery IIRC ... green ones... think there are 2 :)
check here ... depending on which engine you have ....
http://www.omegaowners.com/forum/index.php?topic=90458.0
« Last Edit: 17 August 2012, 15:04:56 by Entwood »
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #2 on: 17 August 2012, 22:16:54 »
Pretty sure one of them only runs with A/C on.
nordic
  • Sunderland
« Reply #3 on: 18 August 2012, 12:45:34 »
Thanks for the help so far :y
Checked the fuses and they are all ok.
Where else should I explore? :-\
(I have a 2001 3.0 V6 auto)
Thanks
Andy
« Last Edit: 18 August 2012, 12:47:15 by nordic »
nordic
  • Sunderland
« Reply #5 on: 18 August 2012, 13:23:32 »
Hi - Tested relays and they are all fine.
Any more thoughts? :-\
Andy
nordic
  • Sunderland
« Reply #6 on: 29 April 2013, 14:45:14 »
It was the electricity supply to the relays. Got there in the end!
Many thanks to all that helped.
Cheers :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 29 April 2013, 17:41:10 »
If the fuses and relay was ok what caused the problem
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 29 April 2013, 17:56:54 »
Well done Nordic... did you find that by doing a multimeter test on the connector (going to the fan) and hooking it up to a decent ground to see if you have battery voltage? :)
also did you then search for a short?
RIP Paul Lovejoy
