Pages: 1 2 [3]  All   Go Down
Author Topic: judder  (Read 6533 times)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: judder
« Reply #30 on: 19 August 2012, 21:16:42 »
Cheers Chris,
I can only see outer parts of the discs. Faily smooth, no rust and no lip on the outer circumference.
I get a brake pad warning flash up on first use of the brakes every day for past week, but it always goes out and doesn't re appear until the next start of journey.
Thanks for your reply.
Re: judder
« Reply #31 on: 19 August 2012, 21:18:36 »
Are the pads low?
Paddy Flannery
    • 2003 2.6 V6
Re: judder
« Reply #32 on: 19 August 2012, 21:26:40 »
Still a few mm. I'm not heavy on brakes. Acceleration sense is king !
Paddy Flannery
    • 2003 2.6 V6
Re: judder
« Reply #33 on: 19 August 2012, 21:30:08 »
Scotty,
I have no intention of hijacking your thread my friend, but I have similar symptoms to you.
scottambrose
Re: judder
« Reply #34 on: 19 August 2012, 21:39:43 »
No probs mate my rear discs look a little worn the front pads and discs were like new but I changed them anyway going to change rear brakes as it needs new h brake shoes il also get the wheel balance checked
scottambrose
Re: judder
« Reply #35 on: 20 August 2012, 19:45:10 »
Seem to habe cured it changed rear discs and pads and swapped rear wheels to front and seems good now alot smoother
Re: judder
« Reply #36 on: 20 August 2012, 19:58:01 »
Good man, didn't think of that. :y
scottambrose
Re: judder
« Reply #37 on: 20 August 2012, 20:55:31 »
Just a quick question when I set the handbrake how should it feel when I spin the wheel shoukd the shoes sound like they rub the disc and feel a little resistance
Re: judder
« Reply #38 on: 20 August 2012, 21:07:30 »
That's how I do it, but I'm no expert, I've only done it twice on an omega that i recall. How does the lever feel...?
Iirc last time I set mine I had two clicks on the hand brake, which settled into 3 clicks once settled in. I'm not saying that's correct though :-\ my memory is vague on that one.
Re: judder
« Reply #39 on: 20 August 2012, 21:33:49 »
From your symptoms mate get your front discs and pads changed earlier rather than later - get genuine Vx disc and pad set  :y
A few mm left on pads + brake pad warning flashing up is bad news - your braking will be seriously compromised (irrespective if you are not heavy on brakes), particularly in an emergency stop situation.  An accident may mean no insurance cover  ???
Pages: 1 2 [3]  All   Go Up
