Author Topic: can I fit vectra 5 stud wheels to my omega  (Read 4037 times)
dezzer3851
  • shrewsbury
    • omega 2.2 auto
« on: 19 August 2012, 19:08:46 »
Dose anyone know if I can fit 5 stud vectra wheels to my omega
Re: can I fit vectra 5 stud wheels to my omega
« Reply #1 on: 19 August 2012, 19:25:56 »
Yup they fit, but look wrong. Too small
« Reply #2 on: 19 August 2012, 19:35:07 »
Depends which ones and what tyres you intend to fit?
Eg an 18" vectra et38 with 245 and rim protection will foul the shock. And a 50 profile will foul the spring cup.
Should be fine in oe sizes though.
dezzer3851
  • shrewsbury
    • omega 2.2 auto
« Reply #3 on: 19 August 2012, 20:31:56 »
Thought that vectras run 16in
« Reply #4 on: 19 August 2012, 21:08:19 »
you can fit..
« Reply #5 on: 19 August 2012, 21:10:18 »
They run a lot of sizes, up to 19" in some cases.
dezzer3851
  • shrewsbury
    • omega 2.2 auto
« Reply #6 on: 19 August 2012, 21:51:18 »
Ok thank u
dezzer3851
  • shrewsbury
    • omega 2.2 auto
« Reply #7 on: 19 August 2012, 21:54:40 »
So I can fit 225\45\16 on mine then
« Reply #8 on: 20 August 2012, 01:18:59 »
you can but 225 50 16 or 225 55 16  will be better imo
2woody
  • Northumberland
« Reply #9 on: 20 August 2012, 11:56:19 »
you can fit, but the offset is wrong.
Expect steering issues
JimE
« Reply #10 on: 20 August 2012, 14:03:38 »
I think the 5 stud Vectra wheels from >02 should fit with no issues. Both  seem to be 5x110 PCD 35 to 45 Offset  65.1 Bore.
 http://www.alloywheels.com/Fitment_Guide/Vauxhall
2woody
  • Northumberland
« Reply #11 on: 20 August 2012, 21:48:02 »
that's a bit vague -is it 35 offset or 45 offset ?
10mm will make a very appreciable difference to your ground-level offset and therefore a big difference to the steering weight and feel.
« Reply #12 on: 20 August 2012, 22:05:09 »
Had both omega and vectra sport stars on mine. No issues what so ever, 8 mm difference in offset. So 16mm difference in wheel track.
If there was any issue to be had on those wheels, buggered if I could find it.
2woody
  • Northumberland
« Reply #13 on: 21 August 2012, 21:39:31 »
just as an aside - which have you got on now ?
and you've got steering issues, right......?
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #14 on: 22 August 2012, 09:37:36 »
Here are Vectra 02's sitting on my Elite.  Offset may be slightly out but tis hard to tell.
These are 17" with the 235/45/17 tyres on !
http://www.omegaowners.com/forum/index.php?topic=45520.0
