Author Topic: Elite Rear Lap Belt Only  (Read 2164 times)
BridgeyBoy
  • St Helens, Merseyside
    • Omega 3.0 Elite Estate Au
« on: 21 August 2012, 14:50:41 »
Hi all
I have recently acquired a near mint P reg 3.0 Elite Omega with only 83k on the clock (see my previous post for pics). I am absolutely made up with it… apart from one thing. The rear seat (leather / heated) only has a centre lap belt. Ideally I would like to replace this seat with a 3 point seat belt. Couple of questions;
1)   Would I need only the seat back or the seat base aswell (there is obviously a seat belt buckle the lap belt in the seat base that’s in there now
2)   If I do have to change the base, will I lose the rear seat heating? i.e are the heater elements in the seat base itself or on the seat chassis underneath
Ideally, I want to have 3 x 3 point belts AND keep the heating!
Cheers
Dave
Re: Elite Rear Lap Belt Only
« Reply #1 on: 21 August 2012, 15:08:19 »
IIRC it`s just a question of aquiring all the components for the centre belt and fitting.  Not sure whether a tapped mounting point would already be there for the inertia reel:-\
« Last Edit: 21 August 2012, 15:15:46 by RobG »
« Reply #2 on: 21 August 2012, 16:11:28 »
Think that might be the issue - Op worth checking first ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 21 August 2012, 20:31:35 »
Can't imagine a P Reg of any spec not having the mounting hole. I wonder why your Elite hasn't a 3 point belt fitted, perhaps it's a converted GLS?  ::)
2woody
  • Northumberland
« Reply #4 on: 21 August 2012, 21:33:51 »
no - this wasn't a requirement at "P"-reg.
Motor manufacturers are lazy - they react really only to legislation. At the start of Omega B, centre lap was the requirement  - and these cars are built as such. For later models, rear 3-point was introduced, to react to legislation. The third point coming from the rear parcel shelf.
I would only attempt this if it can be done with standard components - so you need to make sure that the parcel shelf is out-fitted with the mounting point - an adaptation isn't really "on", for reasons that I shouldn't need to explain.
Changing the parcel shelf isn't easy, mind.
  • Auckland
    • Mazda MPV
« Reply #5 on: 21 August 2012, 22:10:18 »
I have this notion that my old 1994 ('L' reg) CD saloon had a 3 point centre belt.
No way of checking now though :(
« Reply #6 on: 21 August 2012, 22:18:17 »
Pretty sure it didn't  :-\ :-\
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 21 August 2012, 23:11:04 »
Quote:
''I am absolutely made up with it… apart from one thing. The rear seat (leather / heated) only has a centre lap belt. Ideally I would like to replace this seat with a 3 point seat belt''.
Unquote.
You need to touch wood now if thats the only fault  :o :D ;D
only kiddin  :y
RIP Paul Lovejoy
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #8 on: 22 August 2012, 18:33:43 »
I had a 1995 "M" reg Elite and that had a three point harness for the centre seat.
Agemo
  • Cleethorpes
  • Insignia
« Reply #9 on: 22 August 2012, 20:18:41 »
My old 1996 P Reg CDX saloon had a 3 point centre belt.
