Author Topic: Heated Seats  (Read 1519 times)
m.ian
Heated Seats
« on: 21 August 2012, 17:08:26 »
I know it is not the weather to use these but have a "hot spot" on drivers heated seat.
What if anything can I do to sort?
Re: Heated Seats
« Reply #1 on: 21 August 2012, 17:12:18 »
I'm presuming you've got an Elite. The heater pads are sewn to the leather and its a lot of work replacing the pad. Personally I would stop using the seat even unplug it so it doesn't burn through the leather
Re: Heated Seats
« Reply #2 on: 21 August 2012, 21:05:15 »
Asbestos knickers mate  :y
m.ian
Re: Heated Seats
« Reply #3 on: 23 August 2012, 07:58:00 »
OK thanks
Where can you get asbestos knickers? :)
Re: Heated Seats
« Reply #4 on: 23 August 2012, 08:07:22 »
Fit an overlay heat pad for £20 , use mine in the winter and remove in summer ... simples  :)
I_want_an_Omega
Re: Heated Seats
« Reply #5 on: 23 August 2012, 08:42:44 »
All leather (except MV6) and Elite cloth seats are made in the way Pete describes.
The problem occurs as the element is many (actually scores) of strands of resistance wires twisted together and threaded into foam padding. Over time & with wear some of these break increasing the electrical "strain" on the remaining strands which then get hot as you describe.
They will eventually burn through - leaving an open circuit and meaning the heater stops working totally. This can be fixed - but its very fiddly and means stripping the seat right down and mending the break. Problem is that the fault then occurs somewhere else in the seat.
I've put heater pads under my Elite seatcovers and problem solved.
I'd stress that this isn't an insignificant job, it's very time consuming and if the car is your daily driver then that can be a problem. The pads are also becoming more difficult to come by - so another option is to get hold of working seats from a breaker and strip the elements from them - but only from a CD or CDX with cloth as they have the pads fitted but all leather and Elite cloth dont.
All MV6 seats (cloth & leather) have pads fitted, but there is the added fun of a small minipad for the extender knee bolster.
As another poster has said, after market pads are available and these are quite a viable option as well as being good value compared to the cost of the Vx pads ..............
HTH
amba
  • Medway towns
    • German V6
Re: Heated Seats
« Reply #6 on: 23 August 2012, 13:37:24 »
If anybody fancies dismantling an Elite front seat to replace thier damaged heater pad, I have got a genuine VX front heater mat here which was bought some years ago....not trying to hijack thread  ::).....drop me a pm if interested. :y
I_want_an_Omega
Re: Heated Seats
« Reply #7 on: 23 August 2012, 14:11:25 »
Point is Andrew that the Elite heating element is integral with the seat cover - so the mat will needed to be fitted under the cover as I mentioned above. Still have to take all the Hogg rings off though  ::)
As a matter of of interest, is the pad you have from the base or back of the seat? Is it new or used and how much are you looking for it?
Thanks - Rob
Re: Heated Seats
« Reply #8 on: 23 August 2012, 16:14:04 »
OK thanks
Asbestos knicker shop  ::)  or ebay - look here  :) ;)
m.ian
Re: Heated Seats
« Reply #9 on: 23 August 2012, 18:00:18 »
Not sure if they would do my size :) :) :) :) :) :) :) :)
