Tigra A (Corsa B) screen washer help.
Started by zirk, 22 August 2012, 16:59:25
zirk
Tigra A Mot time, front screen washer pump is not working, wippers etc do as they should, any info on Fuse, Relay numbers or wiring info please.
Thanks Chris.
Edit: forgot to add, engine off, ing. on, when I operate washer stalk, dash bulbs slightly dim, so Im guessing something is drawing current, jammed Motor or relay?, or wiring? any thoughts.
Quote from: zirk on 22 August 2012, 16:59:25
Thanks Chris.
Edit: forgot to add, engine off, ing. on, when I operate washer stalk, dash lights slightly dim, so Im guessing something is drawing current, jammed Motor or relay?, or wiring? any thoughts.
Put a multi-meter (lamp) across the terminals going to the pump & see if you get any volts there when you operate the washers. Sounds like it could be a fubar'd pump.  :-\ Is it a hatchback & has a rear screen? What happens if you try to wash the rear screen? It's the same pump (just spins the other way), if you get the same as when trying to wash the front, I'd definitely same a goosed pump.
zirk
#2
Ok, yea Tigra Hatch with front and rear wash, just hunting for the DVM now, just had a quick poke about, its seems the washer (Black motor on top) can be worked loose from the bottle??, or am I going to end up breaking it if I pull it out.
Quote from: zirk on 22 August 2012, 17:16:52
I've never seen under the bonnet of a Tigra, but would assume they use the same pump as other Vauxhall hatches/estates, they all normally just pull out of the rubber grommet in the bottle.
zirk
Thanks Andy, yep just had it all apart, bottles half hidden under the front scuctle, another car built by migets. Pumps gone draws curent both ways but nothing, seem to remember now not if the back one worked.
Just had a quick look at one of the Migs, reckon I can do a temp bodge as cars in for mot first thing, only problem being it will only do the fronts, anyone if the rear wash is a mot fail? Sorry for typos on mobile.
lee4206
Rear washer/wiper is not checked on a mot so you'll be fine.
zirk
Quote from: lee4206 on 22 August 2012, 18:44:03
Great, thanks Lee, I remember it never use to be but wasn't sure if it was on the list after the changes this year.
omegod
Mine stopped working after it's lay up, couple of whacks got it going easy enough. Worth a try :-\
zirk
Thanks sorted. Fitted the Mig one although different connectors, will play football with the old one tomorrow and see what hapens
