Author Topic: Does anyone have....  (Read 1860 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« on: 18 April 2008, 11:15:07 »
...A tried and tested method of syphoning petrol from an Omega fuel tank ( 60litres worth)
Got a small draper "pump" that is totally cac...
Anyone got anything better to use without getting a mouthful of petrol  :(
Re: Does anyone have....
« Reply #1 on: 18 April 2008, 11:17:50 »
Had to drain Marie's tank from almost full when LPG'ing it. Remove the feed hose from the fuel pump plate on the tank. Connect a length of fuel hose and run it into an jerry can or another vehicle.
Remove fuel pump relay and bridge the two wide pins in the socket so the fuel pump runs continuously.   :y
hotel21
  • The Kingdom of Fife
« Reply #2 on: 18 April 2008, 11:18:37 »
funnell, bucket, screwdriver, hammer......
only works the once per tank though....   ;D
« Last Edit: 18 April 2008, 11:18:57 by hotel21 »
« Reply #3 on: 18 April 2008, 11:22:18 »
I was going to mention the screw driver trick but thought against it .....    ::)     ;)
« Reply #4 on: 18 April 2008, 11:23:18 »
I normaly pop the output of the fuel filter off, connect a hose to the fuel filter and short the relay out like Kevin said...
Marie
    • 2ltr LPG Estate
« Reply #5 on: 18 April 2008, 11:29:09 »
I was thinking along these lines but it sounded to simple and stupid so i thought against it. looks like i was wrong :(
Markie
« Reply #6 on: 18 April 2008, 11:46:31 »
Think i will go with the mechanical method although if i get pee`d off at work today hammer and screwdriver may make a guest apperance...
Decided that the oil cooler failure is not economical to repair given the tin worm on the rear arches  :-/
Its here by being broken into tiny little pieces  :-[
Marie
    • 2ltr LPG Estate
« Reply #7 on: 18 April 2008, 13:14:33 »
SO what your saying is your breaking up your migg :'(
« Reply #8 on: 18 April 2008, 13:16:08 »
Not his only Mig, knowing Markie.  :y
I still reckon running the fuel pump is the easiesy way to drain that tank.
Markie
« Reply #9 on: 18 April 2008, 13:21:35 »
No not my MV6  ;D Not the wifes 2.5 facelift  :-X and Not the other star silver Mig......
Its my other other other one thats being broken  ::)
Kevin i`ll be trying out your method when i get home today  :y
« Reply #10 on: 18 April 2008, 13:46:20 »
Just make sure you're on the right fuel line (the one that goes to the filter, or connect to the filter itself as MarkDTM says).
