Author Topic: Tv packed in  (Read 2205 times)
Tv packed in
« on: 24 August 2012, 10:19:34 »
Just when you get break even paying everything and all is well something else crops up  :( tv sounds like a bag of nails and the sound has got a mind of its own  :-\ one minute its all fuzzy and can just about hear it then it goes full blast on own  ::) just forked out for a new washing machine last month now this  :(
Going to take it to bits and see if i can fix it  :-X
Re: Tv packed in
« Reply #1 on: 24 August 2012, 10:47:29 »
this summers surprises were a tv, UPS, monitor, an accident, wishbones for both cars, one engine mount, a chimney (+sat antenna)... :(
and still summer not finished yet >:(
obviously I need deep pockets >:( >:(
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: Tv packed in
« Reply #2 on: 24 August 2012, 12:33:02 »
mine did that then I found out it was a loose connection on the lead going in :)
Re: Tv packed in
« Reply #3 on: 24 August 2012, 12:53:24 »
Sounds like a knackered speaker...
Re: Tv packed in
« Reply #4 on: 24 August 2012, 15:40:45 »
So far i have not touched the tv .... someone got me doing another job  ::) but she makes plenty cups of tea ... thanks for that chaps i will inspect the speaker wires providing i can get the back off the tv first  :-X never took one to bits before  :-\
Re: Tv packed in
« Reply #5 on: 24 August 2012, 21:07:48 »
If its CRT based, be aware that the tube acts as a bloody great capacitor, and it can easily kill you, even with it unplugged.
Re: Tv packed in
« Reply #6 on: 24 August 2012, 21:24:13 »
Had to look that up on wiki  ;D " cathode ray tube" no i dont believe it is on of those ... been delayed for inspection till tomorrow , if it dont work ill be down the breakers for a second hand new one  :( its only for upstairs & swmbo's soap time  ::) ;)
Re: Tv packed in
« Reply #7 on: 24 August 2012, 21:25:28 »
So its LCD or LED then?
Re: Tv packed in
« Reply #8 on: 24 August 2012, 21:30:16 »
LCD
Re: Tv packed in
« Reply #9 on: 24 August 2012, 21:32:01 »
OK, the inverters can generate some high voltages, so unsure its unplugged before removing cover
Re: Tv packed in
« Reply #10 on: 24 August 2012, 21:40:00 »
Will do , just been looking through the online help section for the tv ...
Despite replacing this, the audio o/p ic IC201 KA2201 (TBA820M) and variouscaps around it the fault remained. adding a 0.1mfd cap from the o/p of the ic (pin 5) to chassis, this completely cured the fault
 :D :D :D :D  whats all that about  ;D  will take the back off in the morning  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Tv packed in
« Reply #11 on: 25 August 2012, 12:10:50 »
TBA820 is a low power op amp predominately used for low power Audio, no more than a 1 Watt o/p  from memory, so not sure what its doing in your TV unless its a Head Phone driver, I use to come across them in some Two Way Radio Handportables audio stages, they can go bang, but generally either do or dont work.
Could be a typo and its from the TBA800 range of Amps, probably chucking out 5 watts or so, again they either work or dont, if its intermittent could be dry joint or a leaky capacitor somewhere , but as said first choice would be check speaker and or connectors, speaker will be either 8 or 4 ohms if measured, if you do get the speaker out gently move the cone around and see if you can hear the speaker coil scrapping with movement.
Re: Tv packed in
« Reply #12 on: 25 August 2012, 12:13:00 »
Make sure the household insurance is up to date and knock the tv over ::)
Re: Tv packed in
« Reply #13 on: 25 August 2012, 16:05:54 »
Hopefully it was a false alarm , got all the tools together and swmbo came up and said what you doing  ::) fixing the speaker "why" it was fine last night she said " i just pushed the scart lead in a bit more "  >:( will see if it lasts and if need be i will check all thats be said ... many thanks  :-[ :y
  • Auckland
    • Mazda MPV
Re: Tv packed in
« Reply #14 on: 25 August 2012, 18:08:43 »
SCART (from Syndicat des Constructeurs d'Appareils Radiorécepteurs et Téléviseurs, Radio and Television Receiver Manufacturers' Association)
French and therefore 'characterful' or crap depending on your attitude  ::)
My in-laws previous CRT TV developed a similar fault & I found that all the solder joints between the SCART socket & the circuit board had failed. 5 minutes with a soldering iron fixed it  :y
