Author Topic: eml light and codes read  (Read 2818 times)
bellers
« on: 25 August 2012, 19:26:36 »
my eml light comes on and flickers. seems to be only on at low rpm and then goes of at higher rpm. then after a bit of driving at low rpm comes back on
done paperclip and got 17 and 16 knock sensor currnet 1 and knock sensor currnet 2. any aidea what could be it issue. i dont notice any affect on driving possibly a bit slow pick up at low revs but i could be imagining it  :)
thanks
bellers
Re: eml light and codes read
« Reply #1 on: 25 August 2012, 19:26:57 »
forgot to mention its a 3.0 if that helps
bellers
« Reply #2 on: 26 August 2012, 20:01:32 »
Checked the wires for knock sensors and nothing trapped or no damage to them.
Took it for a good run tonight and doesnt seem to affect driving at all pulls right through revs with no missfire or flat spots
« Reply #3 on: 27 August 2012, 10:32:57 »
if the lights are on, and they are only codes, it will be holding back.
I'd clear the codes out, reset BLMs, and start afresh, see what comes back.
bellers
« Reply #4 on: 27 August 2012, 19:14:02 »
Sorry but whats BLM?
How do i do i clear codes and reset BLM?
« Reply #5 on: 27 August 2012, 19:45:36 »
Given the fault codes given earlier, I guess its either a 2.5/3.0 V6, or a pre 1997 2.0l.
For the 2.5/3.0, tech2 or similar device needed. Don't think a code reset rests BLMs, but honestly can't remember.
For a Pre 1997 2.0l, tech1 or similar. Ditto with BLMs.
The EOBD compatible cars reset trims BLM when you clear codes, but that not relevent to you.
bellers
« Reply #6 on: 27 August 2012, 20:05:57 »
Aye its a 3.0 v6. Shes a 1999 so you recon ive to get it on to tech2?
« Reply #7 on: 27 August 2012, 21:33:57 »
An EOBD/OBDII reader can't do it, so you need a proprietry scanner thats capable of reading codes and resetting BLMs.  Tech2 is the dealer level tool to do this, but other tools may be able to as well.
bellers
« Reply #8 on: 02 September 2012, 16:08:12 »
havent got codes reset yet but im now getting code 74  Mass Air Flow Sensor Voltage High as well as 16 and 17.
hope to get them reset this week
« Reply #9 on: 02 September 2012, 16:27:14 »
Not uncommon for erroneous MAF codes. Looking at live data allows an expereinced operator to know if the MAF is toast.
bellers
« Reply #10 on: 02 September 2012, 21:32:22 »
thanks.
think ill get it onto tech2 instead of a code reader to reset the codes. im off on holidays for 2 weeks so ill call in to vauxhall and see how much it is
« Reply #11 on: 02 September 2012, 21:34:44 »
Dealer will be a waste of space, and charge you a fortune it parts you don't need.
Is there a nearby member? Having a location in your profile helps with this ;)
bellers
« Reply #12 on: 03 September 2012, 09:21:42 »
Lisburn. Northern ireland
