Author Topic: rear air susppention  (Read 1847 times)
CHRIS Dewey
  • DONCASTER
    • Omega elite
« on: 25 August 2012, 20:06:38 »
as u are awear on these cars they have rear air suappension when i start the car the compressor starts but at the same time on the rear passanger side there is a leaking sound as if its filling up but coming straighy out , any advive anyone !!
Re: rear air susppention
« Reply #1 on: 25 August 2012, 20:08:32 »
Check it ;)
CHRIS Dewey
  • DONCASTER
    • Omega elite
« Reply #2 on: 25 August 2012, 20:13:39 »
how ? i have tried feeling foe the leak but no good would i be better taking the wheel of ?
« Reply #3 on: 25 August 2012, 20:16:57 »
It is a case of finding the sound.  Likely areas are where it clips to shock, or at the base of shock if the air bladder has failed.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 25 August 2012, 20:18:37 »
New shock is needed BUT you must change both together.
 Either go for air shocks again or standard shocks which are cheaper.
I put standard shocks on my elite as money was tight...sometimes a regretted decision.
« Reply #5 on: 25 August 2012, 20:20:20 »
Soapy water is a good way to find air leaks
CHRIS Dewey
  • DONCASTER
    • Omega elite
« Reply #6 on: 25 August 2012, 20:21:51 »
guys i apriciate ur feed back but i dont know a lot about these things yea so simple terms would be a great help lol
« Reply #7 on: 25 August 2012, 20:22:28 »
Disconnect sensor arm (centre right in pic) raise lever by hand, should be able to locate air leak
« Reply #8 on: 25 August 2012, 20:25:17 »
Not necessarily, could just be a leaking airline ;)
« Reply #9 on: 25 August 2012, 20:56:38 »
Likely to be a leaking/perished bag on the shocker. IMHO  ::)  :y
« Reply #10 on: 25 August 2012, 21:04:05 »
Needs checking, as other thread. Usually the oil leaks out of the dampers long before the bags fail.
Does the back end bang over bumps? By that I mean, with no oil in the dampers there is no damping of the suspension stroke, so as the wheel hits a bump the wheel takes off and bangs as the spring forces it back on the road. The up slope of speed bumps is a prime example.
« Reply #11 on: 25 August 2012, 21:06:24 »
Both the sets I've changed have failed on the air bag .......  :-\ :-\
« Reply #12 on: 25 August 2012, 21:19:53 »
...trust you to be awkward. ;D
Dampness at the base of the shock is the give away if failed recently. Plus the previously mentioned banging over bumps.
IME for the bag to fail they need to have no air in them, so chaif themselves to bits with suspension movement.
Or maybe the oil has got on the air bag and rotted the rubber maybe...?
« Reply #13 on: 25 August 2012, 21:26:55 »
Possibly  :-\. But you could hear the air escaping both times.  :y :y
