Author Topic: Transmission drip/leak  (Read 3939 times)
cyrusthevirus
  • W.Sussex
« on: 26 August 2012, 16:26:46 »
My ('96 2.5 V6 saloon) autobox is dripping a little atf. I can see the source- its a grey plastic connector of some sort at the top passenger side of the box. Is this a simple repair?
If its a box out job I'm afraid I will have to give up on the car. Shame as it just flew through its MOT & is in bloody good nick :(
Thanks
cyrusthevirus
  • W.Sussex
Re: Transmission drip/leak
« Reply #1 on: 26 August 2012, 17:26:38 »
« Reply #2 on: 26 August 2012, 17:36:33 »
Looks like the speed sensor seal has perished. #10 in this pic
« Reply #3 on: 26 August 2012, 17:43:16 »
From your pic may be doable from underneath.  Not had to do this myself though.
cyrusthevirus
  • W.Sussex
« Reply #4 on: 26 August 2012, 18:40:54 »
Hi cheers for the replys- I don't think its the speed sensor, that fits into the hole next to the prop connection
I'm pretty sure the leak is from whatever it is in the red circle
« Reply #5 on: 26 August 2012, 18:46:17 »
Looks like the speed sensor seal has perished.  .....
Isn't the car's speed taken from an ABS sensor?  :-\
« Reply #6 on: 26 August 2012, 18:49:47 »
#13x in pic. Repair kit for leak
Kit, Repair, Oil Leak, Connector, Automatic Transmission
96042331
cyrusthevirus
  • W.Sussex
« Reply #7 on: 26 August 2012, 19:12:34 »
Thats the darned thing, thanks mate.
I have a horrible feeling it may be unobtanium
« Reply #8 on: 26 August 2012, 19:19:02 »
J Pat may be able to help if no joy with VX (gearbox code is GM4L30, 3rd in the list)
http://www.jpat.co.uk/Parts_cat_GM.html
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #9 on: 27 August 2012, 06:15:52 »
Car speed from ABS, gearbox speed from mentioned sensor. ECU compares these two. Or am I missing again...
sassanach
  • trowbridge
« Reply #10 on: 27 August 2012, 09:18:59 »
you have to drop the sump to remove it.the plastic connector is on a "barbed"fitting.be very carefull as you try to remove it as the plastic goes brittle with age and snaps off......
cyrusthevirus
  • W.Sussex
« Reply #11 on: 27 August 2012, 17:45:39 »
Thanks for the replys, really appreciate it  :y
Will see how much the dealer will quote for the part & how much I can get it fitted for tomorrow (not something I can do myself on the drive).
If worst comes to worst, are they are breakers who would want to buy the car? I'd rather some use was made of it that just weighing it in. Otherwise its a very clean car which just needs tyres/front wheel alignment and a crack in the corner of the windscreen. Thanks again
cyrusthevirus
  • W.Sussex
« Reply #12 on: 28 August 2012, 09:12:30 »
the part is available to order and costs £73. My local dealer hasn't fitted one before, should I entrust them or find a gearbox specialist? thanks
Marie
    • 2ltr LPG Estate
« Reply #13 on: 28 August 2012, 13:03:43 »
Gearbox specialist without a doubt! x
amba
  • Medway towns
    • German V6
« Reply #14 on: 28 August 2012, 13:23:48 »
Wouldn,t trust a VX dealer to stick a stamp on a letter ;D let alone work on an Omega
