Author Topic: 2.2 auto estate gearbox oil level check  (Read 1404 times)
flyer
  • Telford Shropshire
« on: 26 August 2012, 16:47:26 »
What is correct way to check auto gearbox oil level and can you advise as to the location of the gearbox ECU
Re: 2.2 auto estate gearbox oil level check
« Reply #1 on: 26 August 2012, 16:51:05 »
ECU is up behind the drivers kick panel under the dash.
Level check http://www.omegaowners.com/forum/index.php?topic=90508.0
« Reply #2 on: 27 August 2012, 10:31:09 »
Don't change gearbox ecu until proven faulty. Only ever seen 2 faulty gearbox ECUs, so ignore any mechanics pointing fingures are Omega ECUs.
