Wanted: Facelift Scuttle
Started by D, 26 August 2012, 22:02:56
D
Facelift scuttle panel wanted, including the backing foam bit. Needs to have intact lugs (under the windscreen seal), and in good condition (not leaking/perished ideally). Ideally from one car, rather than 2 halves so that the trim matches visually, if that makes sense? It would be nice if you have the securing lugs as well, but not too bothered if you don't have them. Thanks.
