Author Topic: Crows foot spanner ............  (Read 2188 times)
I_want_an_Omega
« on: 28 August 2012, 19:47:54 »
Re: Crows foot spanner ............
« Reply #1 on: 28 August 2012, 19:49:51 »
Is this what's needed for V6 oil pipes near the oil filter?
http://www.ebay.co.uk/itm/NEW-3-8-Drive-CROW-FOOT-SPANNER-WRENCH-19mm-SPCRW19-/130710148415?pt=UK_Hand_Tools_Equipment&hash=item1e6eee953f
Thanks ..............
Yep :y
Although you could invest in a rail for not much more money than that :)
I_want_an_Omega
« Reply #2 on: 28 August 2012, 19:51:47 »
Yep :y
Can you clarify please James - I dont understand  :-\
« Reply #3 on: 28 August 2012, 19:53:30 »
I was referring to a rail of crowsfeet sockets, ranging from probably 10mm to 21mm, rather than an individual socket.
But the link you post is the correct part for the oil cooler pipe to block unions.
I_want_an_Omega
« Reply #4 on: 28 August 2012, 19:55:22 »
Gotcha - thanks
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #5 on: 28 August 2012, 19:57:07 »
I concur - Machine Mart keep them in stock IME, about £12 IIRC.
I_want_an_Omega
« Reply #6 on: 28 August 2012, 20:05:05 »
Thanks - I'm passing one in a day or two and will take a look ......... www says they are £17.99 though - hey ho.
« Last Edit: 28 August 2012, 20:08:19 by Lincs Robert »
« Reply #7 on: 28 August 2012, 20:29:30 »
www is probably more right than me, it's been a few years since I bought mine. ;)
amba
  • Medway towns
    • German V6
« Reply #8 on: 28 August 2012, 21:40:13 »
Suggest you get one with a very tight fit onto a ratchet or extension as if they fall off be certain it will end up behind the engine mount and no amount of magnetic retriever tools will recover it. >:(
Bet more Omegas have 19mm crows foot wrench sockets behind n/s engine mount
Kieran
  • Dorset
« Reply #9 on: 28 August 2012, 21:47:55 »
Just removed mine. It is a tight fit but you are correct a 19mm is what you need.
I_want_an_Omega
« Reply #10 on: 28 August 2012, 21:52:15 »
Noted: Thanks Andrew
Agemo
  • Cleethorpes
  • Insignia
« Reply #11 on: 28 August 2012, 22:50:28 »
"I'm passing one in a day or two and will take a look"
Sounds painful.    :o
« Reply #12 on: 29 August 2012, 19:36:36 »
Sounds painful.    :o
Especially the whole rail...  :o
