Author Topic: Dti fault codes  (Read 1149 times)
spudmariner
  • Portsmouth, Hampshire
Dti fault codes
« on: 29 August 2012, 17:43:48 »
Hi there, I have a 2003 GLS dti estate that is giving me problems. The eml came on a few weeks ago and showed 2 faults on diagnostics. firstly the EGR valve which I replaced and also ' inconsistent pressure from fuel pump' which was cleared and the car was ok for a couple of days and then the light came back on intermittently puuting the car in 'limp home' mode and after a few mins would clear. However, now the car is in permanent limp home mode with the light permanently on. If the fuel pump is knackered then its not really financially viable to replace. What puzzles me though is that when in neutral, the car will rev freely right across the rev band with no hesitation so I must question whether the fuel pump is really at fault. I'm still using the car as on the flat it isn't too bad but going up hills is a struggle. Any ideas please? Thanks.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Dti fault codes
« Reply #1 on: 29 August 2012, 18:20:17 »
What codes are you getting now? EGR (0400) codes usually relate to a leak on the vacuum pipe network on the 2.2 Dti's...
