Author Topic: Going to drive her of a cliff orbetterstill torch her!!!!!  (Read 4427 times)
Marie
    • 2ltr LPG Estate
has had enough of it im Threaders.  >:( >:( >:( >:( >:( >:(
Spent all day sorting out the Gas leak that i thought we fixed but clearly didnt :'( :'( :'( :'( but its never that easy had to take the vapourizor out to undo the cap to replace the seal but to take the Vapourizor out you have to drain the coolant ( just bl*#+y changed it !!!!)
Well put it all back together and low and behold still leaking so round again  :'( :'( :'( :'( :'( but this time she decides she going to cut my arm open and i now also have a lump / bruise forming between my knuckles which doesnt seem to wanna stop swelling. icepack required i thinks lol
Now i am just waiting for the liquied gasket to set then im going to test her again.
so god help her it best have worked or shes toast!!!!!!!!!!!!!
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Going to drive her of a cliff orbetterstill torch her!!!!!
« Reply #1 on: 30 August 2012, 16:52:29 »
Have you tried spraying soapy water on all the suspect areas?  When you find the leak you'll see it straight away :y
Chin up old girl  :-* :-* :-*
Marie
    • 2ltr LPG Estate
« Reply #2 on: 30 August 2012, 16:59:21 »
ihave found the leak but there is a v tiny chip out the leading edge fofthe mating surfaces so the standard o ring seal doesnt seal it :(
have gone into work and robbed some neoprine and made a flat seal that goes beteen the surfaces and filled the chip with liquied gasket. tightened it up and now i wait how long does vx liquied gasket taketo go off?
now i am on the hunt for an lpg filter as hewants to bill me £40notes for one lol
and less of the old you pmsl  ;D ;D ;D ;D ;D
« Reply #3 on: 30 August 2012, 17:01:45 »
I'd leave it overnight to play safe  ;)
Gaffers
« Reply #4 on: 30 August 2012, 17:03:33 »
24 hours normally, but I guess it depends on how much you used.  Did you clean the surfaces with a suitable solvent?
You could try eBay for filters, some fairly decent prices on there.
And you said it yourself, you ARE the SENIOR service. ;D
Marie
    • 2ltr LPG Estate
« Reply #5 on: 30 August 2012, 17:12:59 »
didnt need alot just enough to fill the v some chip
just looking on ebay now lol
and if this dont work ill need a new vaporizor  :'( :'( :'( :'( :'(
really not a happy bunny just wanna cry!!!!!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 30 August 2012, 18:35:04 »
If it doesn't work the way you have tried how about filling the chip with JB weld and when dry filing/sanding it smooth so the O ring works again on its own :y
other rides
Marie
    • 2ltr LPG Estate
« Reply #7 on: 30 August 2012, 18:43:08 »
not a bad idea ....
well hubbys neoprine gasket didnt work just cut through it :(
so i have just removed the end and cleaned it all up
ptfed the thread then put liquied gasket round the mating edge then put the o ring back on then added a little more liquid gasket so when i tighten it up it squeezes out filling said chip. letting it set over night and pray it is enough
i am on the verge of tears she is beeting me and i dont like it!
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #8 on: 30 August 2012, 20:10:36 »
It's a bit early for bonfire night, so hang on in there young girl.  ::) ::)
If you can't reliably repair your vaporizer, you maybe able to get a cost effective replacement off fleabay.
http://www.ebay.co.uk/sch/Vehicle-Parts-Accessories-/131090/i.html?_nkw=lpg+vaporiser
Marie
    • 2ltr LPG Estate
« Reply #9 on: 30 August 2012, 20:14:43 »
thank you  :y :y have been looking through ebay but cant find the right one i hav a AC stag 300-4 kit fitted to my motor.
managed to find the right size filter though.
still praying the liquid gasketand o ring work.
« Reply #10 on: 30 August 2012, 20:34:24 »
Marie, post up a picture of the offending item ;)
I might be able to get a decent price on a replacement Vap and filter if you need it as I can still get in touch with Teilo (sometimes ::)) :y
Marie
    • 2ltr LPG Estate
« Reply #11 on: 30 August 2012, 20:37:32 »
thank you darlin.
its fitted to the car at the moment  :-\
opps just had a thought i have a pic on my phone ..... how do i get it from my phone on to here
 its not the best pic in the world though mind :(
« Last Edit: 30 August 2012, 20:39:10 by Marie »
« Reply #12 on: 30 August 2012, 21:08:59 »
thank you darlin.
Upload to a photo hosting site like photobucket... There's a guide somewhere.
Sorry, I read it like it was off the car overnight ::)
Is it actually the vap leaking or where something connects to it?
Marie
    • 2ltr LPG Estate
« Reply #13 on: 30 August 2012, 21:52:58 »
sorry its a bad pic would have done a better job if i known it wasnt going to go to plan
« Last Edit: 30 August 2012, 22:02:08 by Marie »
« Reply #14 on: 30 August 2012, 22:13:53 »
Can't actually see the damage you refer to but have PM'd a potential solution :y
