Author Topic: AR25/35 component needed (fairly) urgently  (Read 2157 times)
« on: 01 September 2012, 16:16:58 »
Hi Guys
On the 25/35 gearbox, there is a connector inside the main sump which controls the solenoids in there. It's round - and a round connector from the loom plugs into here.
I need the round connector that sits inside in the autobox, and plugs in to a multi plug that lives within the main sump.
It needs the sump taking off to remove, and is very fragile in the way it fits inside the box from what I can see, so will need gentle hands to remove.
Any help I'd be much obliged :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: AR25/35 component needed (fairly) urgently
« Reply #1 on: 01 September 2012, 16:36:08 »
think ive got that james...is it round and red with 6 pins
Steve B
  • Leicestershire
« Reply #2 on: 01 September 2012, 16:41:33 »
« Reply #3 on: 01 September 2012, 17:12:45 »
The red bit in your picture is the bit that plugs into the underside connector I need - which pushes fown into the gearbox from the top, into the sump.
So, not quite, but very close! That red connector in your pic basically plugs into the bit I need!
Steve B
  • Leicestershire
« Reply #4 on: 01 September 2012, 17:24:37 »
oh right..amba has recently swapped his box so pm him see if he has old one still..ps did you get my pm. :y
