Author Topic: New purchase in Portugal.  (Read 4131 times)
trainschi
  • Portugal
    • Opel Omega 2.5 TD
« on: 01 September 2012, 20:35:55 »
Hello all I have emigrated to Portugal and I have just bought today a Opel Omega Caravan TD, 2.5 Diesel as they are called here.
it is a 2000 model and has 179kms on the clock, you dont want to know what I paid for it as second hand car prices here are ridiculous!
I have been driving all over the country for the last 2 weeks looking for something close to decent on my budget.
So anyway found this beauty which will serve my purposes well.
To the point, the car drove well under test apart from one thing, it seems sluggish at low revs, ie below 2000k, till turbo kicks in, it even stalled when I tried to go up a steep hill till I got the revs over 2000k, so my question is do you think there could be a problem with it or could it be the fuel filter problem I have read on here?
Everything else checks out about the car and there are no other faults detected, no strange noises from anywhere etc.  They do neglect their cars here and I just think it is suffering from a bit of lack of care.  I will do all the usual when I get my hands on it next week, ie a full service, and the first garage job will be the cam, tensioner and water pump work.
Any pointers much appreciated, I haven't had time yet to read through all the posts here but will do to increase my knowledge.
Thanks a million and all the best.
Re: New purchase in Portugal.
« Reply #1 on: 01 September 2012, 20:38:24 »
Chain on a diesel, aux belt drives waterpump
« Last Edit: 01 September 2012, 20:40:00 by RobG »
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 01 September 2012, 21:09:33 »
As above. Also you should give it the Diesel Magic trick to clean the injectors.
« Reply #3 on: 01 September 2012, 21:24:32 »
A new fuel filter would be my first job.  :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 01 September 2012, 21:33:04 »
On the occations i have been to portugal i noticed that it is very dusty so as an add on to the above a new air filter would be a good move, bet it's due a change :y
Check all the hoses to the intake and turbo for small cracks and clips for tightness, if suspect then new wont be a waste of time.
Jaguar XJ6
trainschi
  • Portugal
    • Opel Omega 2.5 TD
« Reply #5 on: 01 September 2012, 22:20:47 »
Thank you very much for the replies so far, very helpful, I will know much more when I fetch the car on Monday and get it back to my garage, 3hr drive from Lisbon, wish me luck, but plan to change the oil and all the filters as suggested, I will also look at the brakes and see what needs doing there if anything, this car has been used as a daily driver, so I don't expect too much horror!
I have owned Vauxhalls in the past and always found them to be very reliable and trouible free.
I have in the past owned a Mitsubishi delica 2.8 tdi, my first ever diesel, I had a bit of experience cleaning the injectors, replacing nozzles and re-building the pump on that, not an experience I would gladly repeat I must say.
Also encountered the cam chain and tensioner on that engine, and assume from RobG's brief post that this engine has a chain and tensioner.
So thinking out loud before even checking the car I should maybe be prepared for the possibility of tackling fitting a new tensioner.
Bringing me neatly to my next questions,
is this fairly easy? and is it possible to get hold of a workshop service guide for this car fairly easily?
I don't mean a haynes manual, but a proper garage manual used by vauxhall,
I used to have one for the the deli and it was worth it's weight in gold.
Here is a link for the old girl if you want to take a squiz, please don't whince at the price, its normal here  ;D
http://www.custojusto.pt/Lisboa/Ligeiros-Passageiros/Opel+Omega+2+5+TD+caravana-5788407.htm?xtcr=1&last=1
  • Auckland
    • Mazda MPV
« Reply #6 on: 01 September 2012, 22:37:34 »
The 2.5 6 cylinder diesel is the same BMW engine that found it's way into the Range Rover.
There was a link somewhere to the Range Rover manual for the engine. If I can find it I will let you know.
  • Auckland
    • Mazda MPV
« Reply #7 on: 01 September 2012, 22:47:13 »
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #8 on: 01 September 2012, 22:47:49 »
http://rapidlibrary.com/source.php?file=ulzezefenmi89on&url=http%3A%2F%2Fimages.omegaowners.com%2Fdocuments%2F25TD%2FM51D25_Engine.pdf&sec=88756455198dd550
I think this is it. I have a TD, the main thing is to change the oil every 3K, use VX 10W-40. If the water pump is original, swap it for one with a metal impeller. They have a habit of shedding the plastic vanes. If looked after, the engines are pretty bullet proof. Good tuning chips are available for these also. Search on this forum. Good luck, I've had mine for 13 years with no serious problems. :y
Note to self: Must type quicker!
trainschi
  • Portugal
    • Opel Omega 2.5 TD
« Reply #9 on: 01 September 2012, 22:59:58 »
Cheers guys, that's fantastic, just what I was after Andy, thanks for the tips also Shackeng, hope mine goes on that long! very grateful both, I will keep you all posted of the progress and give an update on Monday after the initial inspection :o,
all the best.
« Reply #10 on: 01 September 2012, 23:25:26 »
Is it a manual or auto? If manual you can chip it back to BMW full spec, it was de-tuned for the Omega  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #11 on: 02 September 2012, 08:49:54 »
Looks very nice, (but trying very very hard not to wince at the price)   ::)
« Reply #12 on: 02 September 2012, 10:04:00 »
Replacing the chain, tensioners and guides are fairly easy. I bought my parts from BMW as they were much cheaper than from Vauxhall. You'll need a locking/timing kit to do the job properly though ;)
trainschi
  • Portugal
    • Opel Omega 2.5 TD
« Reply #13 on: 04 September 2012, 23:56:36 »
I would have difficulty in getting a locking kit over here, see its a bit of a problem even finding basic parts when you only speak basic language, anyway I went to a local garage today and asked for a quote for the work and the mechanic came out with the parts manager and it was like a classic from a movie, very funny, there was much shouting and waving of arms and very worried faces.  They said they couldn't tell me how much but they would give me a quote for the parts alone.  I will be going to the local Omega dealership tomorrow and asking them to check over the car and quote for the engine work that needs doing, so far what I have found out today,
No coolant left in reservoir  :o get real hot driving up a mountain to where I live!!!
Flat battery, charging over night to see if knackered.
All disks and pads need replacing.
All filters and fluids need replacing, and putting back whats not there in the case of the coolant, Read the how to on flushing etc, on this, cheers.
Split breather hose
Broken glove box handle.
Broken ash tray, I don't smoke, but it hanging out and not closing reminds me of when I did.
So not too bad really, mostly wear and tear and neglect :'(
That' what I have discovered so far, anyway I am pretty sure the injectors need work,
and I will do the diesel tank work as shown on here and post some pics with what I find, expecting lots of sludge
Oh yes, it is ticking over about 600rpm and lots of vibration, like an old bus, when I increase revs to about 900, it is sweet like sewing machine, think this is still pointing to fuel starvation or air filter, or both, will know more tomorrow.
Let you know what Opel say too, should be a laugh, main dealer prices  ;D
PS: Could anyone recommend any suppliers for the performance chips, have you had good experiences, reliability etc, many thanks, all the best.
Omegatoy
  • UK
« Reply #14 on: 05 September 2012, 08:19:30 »
I found vibration was down to engine mounts!! sounds like yours is the same with the heat etc in portugal, they dont normally use coolant, temp going up is normal if oil and filters havent been changed for a while,it looks a lot but is usually only 5 degree,s or so, plastic impellors can lose some of their fins so would be worthwhiloe checking and radiators are known to sludge up!! if its the same as here in spain, then there are many places who will do a chemical clean on the rad very cheaply to sort that!!
chops, you need the ten digit number off the ecu, also open the ecu and check to see if you have a socketed carrier in there or whether you need to solder one in, when you have the  number pm it to TB he will see Terry and sort it i would think,
I have persnally done over 90k on 3 different cars all with the chips in and never had a problem except better fuel consumption and an easier drive!!!
