Author Topic: Driver's Door Locking Motor Needed For A F/L  (Read 2988 times)
waspy
« on: 02 September 2012, 10:57:15 »
As above please. Mine's decided to throw in the towel.
waspy
Re: Driver's Door Locking Motor Needed For A F/L
« Reply #1 on: 02 September 2012, 11:17:09 »
Just removed the offending thing. I see they're not handed so I guess any side please :)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 02 September 2012, 13:58:41 »
Got a rear door one here, not sure if they are different??
twiglet
  • Norwich, Norfolk
« Reply #3 on: 02 September 2012, 14:03:08 »
« Reply #4 on: 02 September 2012, 14:13:29 »
I will probably have one sometime within the next week.If you havent found one by then gimme a shout. ;)
waspy
« Reply #5 on: 02 September 2012, 15:46:23 »
In what way are they different James? I see the top white part can be swapped over (or at least it slides out) on the driver's side.
Is the plug different?
The central locking still works without the motor, but obviously you need to use the key to actually lock the driver's door.
waspy
« Reply #6 on: 02 September 2012, 15:46:48 »
Thanks mate :y
twiglet
  • Norwich, Norfolk
« Reply #7 on: 02 September 2012, 16:09:42 »
The white part that connects to the mechanism is different, as is the part number.  IIRC the front ones contain 2 micro switches as opposed to 1 in the rears.  I think this is to activate the deadlock system.  :y
waspy
« Reply #8 on: 02 September 2012, 16:49:31 »
There is two micro switches in the one on the driver's side (don't know about the pass side). I guess it will have to be a driver's side that replaces it then. Unless someone knows other wise.
« Reply #9 on: 02 September 2012, 16:52:40 »
N/S & O/S fronts are the same through MFL to F/L
waspy
« Reply #10 on: 02 September 2012, 16:56:29 »
Thank you Rob :y
waspy
« Reply #11 on: 05 September 2012, 17:00:27 »
Still in need if anyone has one?
mantahatch
« Reply #12 on: 08 September 2012, 20:16:56 »
If your handy with a soldering iron I have new microswitches you can have.
waspy
« Reply #13 on: 09 September 2012, 20:22:28 »
Thank you for the offer. I'm good with a welder, but soldering is not my forte :-[
I have some on the way soon. Over to you Mr Admin :y
