Induction kits
Started by mdziyaad, 03 September 2012, 12:12:47
mdziyaad
hey all,
can't seem to find any induction kit for the 3.2ltr.. any reason why?
They are a waste of time. Increase in induction noise (if that what you want) but a decrease in power & torque.
will bring a negligible performance increase (without other mods) and may decrease performance if not designed properly (suck hot air) ..
also you may easily harm your maf..
mdziyaad
scraped that thought... any other suggestions btw increase performance?
Quote from: mdziyaad on 03 September 2012, 13:37:35
ECU can be flashed with a re-map. Only gain around 10 BHP though
mdziyaad
a friend suggested to have the engine modified mechanically first then fiddle with the ECU.
What say?
modding a 9 year old car means high cost in my dictionary.. before modding you need to bring the engine condition to maximum.. when you start mechanical modifications you may face expensive parts giving up..
so first I would be sure of the engine health..  of course if pockets are deep its not a problem and there are many alternatives ..
tigers_gonads
Nah, thats for girls  ;D ;D
You want to have a word with these lads
http://www.steinmetz.no/Home.aspx
ozzycat
dont remap it hurts i know
long live the magic tree
its good to be back
scottambrose
my induction kit is mounted at the front of the airbox so you cant see it when you open the bonnet and the airbox is still there complete aand has a pipe inside so the airbox is just cosmetic and the filter sits right behind the headlight where the cold airfeed is.
tigers_gonads
Quote from: devonscott on 05 September 2012, 10:39:42
Unless the lid is on and sealed up, you will still pull in hot air from around the engine bay which will drag your bhp down  ;)
Also if you have used the oil on the cone filter which some manufacturers supply, it will find its way down to the maf sensor and destroy that too  :(
Years ago i ran a vectra 2.5 with a cone filter on with direct cold air feed , while low down pickup was bogged down , the top end of the rev range it use to run better and more responsive ... never oiled the filter just blew it out with compressed air now and then . The days of traffic light drag strips  ;D :-X
scottambrose
yes lids on but the box has been adapted to house a pipe that links to the filter and the air intake tube. and the filters not oiled. made that mistake with a v5 toledo i had i had to clean the maf every few weeks
Doubt it would be large enough to have the flow of a genuine GM filter - the standard Omega one is bloomin' huge!
