E11
Started by mdziyaad, 03 September 2012, 12:17:43
mdziyaad
Ola!
i'd like to know what kind of tweaks i could do on my elite, it's a daily runner and i'm pretty much on the highway averaging 60 miles + on distance and cruising between 80 - 90 mph
Danke!
Tweaks for what purpose?
mdziyaad
to make the ride better? :o
mdziyaad
sorry, was a bit too vague! well, i would want to decrease the gear ratio so that it could rv aroun 2500 - 2800 rpm @ 90 Mph.. that sort a thing
You'd need a different Diff, all the ratios can be found on this site :y.
Only real option to lower the gearing on the 3.2 with a 3.9 dif is to fit a 4.2 dif from 2.6.
It works well, but you'll see higher rpm at cruising speeds, which can be tiresome for some. Although I don't notice it tbh. Mpg may increase too.
Quote from: chrisgixer on 04 September 2012, 10:09:50
you mean decrease..
OP want lower RPM, not higher. ie, less acceleration (well, I'm sure he doesn't, but thats a by-product).
A TD 3.7 diff may be the way to go.
twiglet
Quote from: TheBoy on 04 September 2012, 18:03:00
Or a 3.45 diff from a dti... Assuming it can take the power of the 3.2?  :-\
Quote from: twiglet on 04 September 2012, 22:33:06
using a lower ratio differential and 3.2 is pretty useless.. by a 1.6 and go slow ;D
