Author Topic: Help needed, pretty please :-)  (Read 1911 times)
grain.ben
« on: 03 September 2012, 18:44:16 »
as per above, im sure one of you fellow OOFers out there could help me fit a new window mechanism? os rear window cable snapped and i would like to use all of my windows. I dont have the knowledge or tools to do it. Many thanks  ;)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
Re: Help needed, pretty please :-)
« Reply #1 on: 03 September 2012, 18:49:37 »
 i would love to help but im; miles away :) ;)
grain.ben
« Reply #2 on: 03 September 2012, 18:51:06 »
i used to live just over the hill from you in Holmfirth, ahh shame, cheers anyway  :y
« Reply #3 on: 03 September 2012, 18:59:31 »
As your profile says "CD" assume leccy rears. Doorcard off, unplug motor, drill rivets out, fit replacement
grain.ben
« Reply #4 on: 03 September 2012, 19:05:45 »
i know the gist of doing it, but would rather have someone with me incase i run into problems.
Yes leccy rears
also, the cable has snapped, so whats holding the blooming window up?? :o (as ive just noticed, the window seems to be slipping down mm by mm as there is a small gap at the top and letting water in through the seal when i wash her)
also, dont have a riviter nor know how to use one  ;D
« Reply #5 on: 03 September 2012, 19:14:11 »
Yes leccy rears
Yep, over time it`ll drop fully
grain.ben
« Reply #6 on: 03 September 2012, 19:20:45 »
it was fully closed when i bought her nearly a year ago, the gap is about 3mm.
So, what exactly holds the window on the mechanism? is it that rectangular white plastic block at the top? and does it just slot on or screw in?
swordfish
  • manchester
« Reply #7 on: 03 September 2012, 19:49:01 »
 get some maskers on temp fix . at least it will keep the water out   ;)
grain.ben
« Reply #8 on: 03 September 2012, 19:55:46 »
im not worried about when it rains, its only when ive got lots of water on it, i.e hosepipe when im washing her, otherwise it doesnt leak.
« Reply #9 on: 03 September 2012, 20:55:43 »
If you bring it here, I'll happily go it.  Bloody facelift rear door windows mechs ;D
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #10 on: 03 September 2012, 22:17:57 »
Once the rivets are drilled out the arm will just slide out of the metal bit at the bottom of the window, drill the rivets out and it will be pretty obvious.
grain.ben
« Reply #11 on: 03 September 2012, 22:30:59 »
cheers for the info guys, will get it sorted  :y
TB pm sent  :P
Page created in 0.029 seconds with 16 queries.
