Author Topic: ABS control unit  (Read 1827 times)
phantomdriver
ABS control unit
« on: 06 September 2012, 15:07:52 »
2.5 V6 1988
Can they be refurbished?
vauxhall quote £600 plus fitting, twice the value of my old thing... :-\
Re: ABS control unit
« Reply #1 on: 06 September 2012, 15:11:47 »
Can be refurbed for around £130. Could source a compatible used one for around £40. Used one is a bit of a gamble as it could go wrong at some point.
phantomdriver
« Reply #2 on: 06 September 2012, 15:14:29 »
any ideas as to where, as I'm running out of ideas to source one.. :y
« Reply #3 on: 06 September 2012, 15:24:53 »
Im sure someone will be able to provide details of places which do refurbing soon. As for sourcing a used one. You will need to provide deatials of your car - year,engine size etc. :y
phantomdriver
« Reply #5 on: 06 September 2012, 16:28:03 »
Ok, just to be sure that I have the correct unit..., the symptoms...
ABS light , and intermittent speedo failure
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #6 on: 06 September 2012, 16:31:27 »
Or BBA Reman
There is a maintenance guide on here on how to take off and replace.
1998 car?
MFL onwards from late 97 were prone to this problem. Can also affect your variable power steering. I had your symptoms on one of my four failures
phantomdriver
« Reply #7 on: 06 September 2012, 16:34:40 »
come to think of it, the power steering  failed once, so ............. ???
Page created in 0.01 seconds with 14 queries.
