Replace or refurb wishbones
Started by TheBoy, 06 September 2012, 22:20:36
Quote from: chrisgixer on 08 September 2012, 10:26:38
While its easy to advise what you would do on your own cars, with the expertise you have available, it's the op that we need to bare in mind.
A valid point in any scenario :y
While its arguable re-furbing is the way, not all owners have confidence to mess about. Plus the possibility of introducing further faults in the process.
Although its equally likely that some part of the new part could have introduce faults.
Quote from: Jimbob on 08 September 2012, 12:30:43
i seem to recall they were about 1 month old!
So well within warranty when they failed...  ...but the warranty isn't really feasible.
Quote from: aaronjb on 08 September 2012, 13:01:23
If a 10t press is easier than a large vice for the rear bushes... I now own a 10t press  :-[ welcome to come use it anytime ;) (especially if you help me assemble it and put it on the workbench!  ;D)
I'll give you a few days to build it ;D
Quote from: Andy H on 08 September 2012, 13:29:40
PS there is no way my vice would be hefty enough to shift those bushes. It might be up to the task of pressing the new ones in though.
I'm probably luck in the respect my fronts are already polyed, so they will just fall out, and the rears have only been in 2 years. Although 2 years is disappointing from genuine GM.
Quote from: TheBoy on 08 September 2012, 13:56:06
exactly, would be without the car for weeks while no wishbones as sent of for inspection, then replaced.  not worth it.
Has anyone tried the Meyle wishbones?
Quote from: TheBoy on 08 September 2012, 13:50:51
Struggling now to find a suitable socket to fit the front bushes.......
I think the recommendation would be to cut out the fronts, and use polys instead
That is the plan. I just prefer to press the old ones out if I can.  :) Failing that make a single cut in the outer bush (and then press it out).
only recently been available afaik.
I am running the meyle HD droplinks, and am very impressed, seem the best quality ive ever had.
Quote from: Andy H on 08 September 2012, 14:32:03
Think you'll need a good press to get fronts out....
Quote from: Jimbob on 08 September 2012, 14:32:07
I've used Elring gaskets before, but wouldn't use them on Omega camcovers ;)
Quote from: TheBoy on 08 September 2012, 14:40:09
They're out !  :y
They took a fair bit of force & when they did go they went with a bang and a cloud of rust. I cut most of the way through the outer bush but I didn't want to score the bore in the arm because that is what the polyurethane bush will be seated against.
Just need to drill the rivets out of the balljoints & then I can start reassembly.  :)
Quote from: TheBoy on 08 September 2012, 14:13:22
it's less than two years, the pull you have now is the same Slight pull you had after we re tightened the the wb bolts. Just It's worse. Which directly reflects the condition Of the worst bush that's failed.
The bush may have failed on the under side, hence we didn't spot it when tightening bolts. But it's the same, but worse, fault.
As a note, those symptoms that you may remember, are indicative of a failed rear ward bush. Loose bolts(ESP the rearward) and failed rearward bush give that same odd pull on the brakes. It's effectively shortening the steering tie rod length on one side. Which makes the steering wheel turn in your hands in order to keep the car straight.
If anyone has that fault it's the rear bush. Not something we see often in help section iirc..,?
Although we may do now more people have polly I suppose...?
