cheap tail pipe trims
Started by swordfish, 07 September 2012, 19:20:37
swordfish
just thought i would let you know about these tail trim pipes i got for my omega. ;D they fit a nice tight fit over the standard tail pipes on my elite. and the outlet size is 3 inch [ so not to big]  they come with clamps but you dont need the clamps as they are such a good fit [ need tapping on with a rubber hammer . they wont be coming off  thats for sure  :they are also slash cut and perferated so don't sound like a wet fart and fit the shape of the bumper good . best bit of all though is they are only 10 pounds each [ free delivery] hears the ebay number
                                                    320848545385    cheers carl  :y :y :y
They look good quality , maybe fit a jublee clip around them to stop them being pinched ..... thanks for the link  :y
BlueBridge
Jon
Look good, I'll be looking for some soon. Wondering what a stainless exhaust place would have for ones to be welded on  :-\
Seth
Quote from: EMD on 07 September 2012, 19:37:13
A 1/8" pop rivet might be an effective option ;)
kevin xf
 :y cheers for that.  I'm getting them  :)
Quote from: Seth on 08 September 2012, 00:46:15
Aye  :y I had some similar on the twin outlet v6 veccy , they butted up quite tightly in the center but still used the securing bolts the supplied  :y
x25dt
Not any more they aint.  :-\
Quote from: swordfish on 07 September 2012, 19:20:37
Quote from: Mr Skrunts on 10 September 2012, 10:41:13
A mass influx of omega owner's wanting them  ::) :-\
swordfish
have they gone up or are they out of stock ???
Quote from: swordfish on 10 September 2012, 16:33:10
Nope, still listing loads on that auction?
Although that said, now couple of quid for delivery  :y
DezB
Very nice, what is the diameter of your exhaust?
Mine is 60mm and the unit also is 60mm, did you have any difficulty in getting to fit?
swordfish
yes they are a tight fit. you need to clean the pipes and scotch bright them and put a bit of grease on ,then tap them on with a rubber mallet
but make sure they are lined up correctly . :y
