Author Topic: 2.2 auto box problems  (Read 1920 times)
tal
« on: 07 September 2012, 21:30:54 »
Hi. I've just got a 2.2 estate auto. The gearbox has started playing up. It drives smooth for a while but then seems to go into limp mode and is very slow to pull away. The display says Automatic Gearbox fault  but no other lights come on. It's better shifting it manually until I can pull over and restart the car which seems to solve the problem for a while. Any advice would be appreciated. Cheers
Re: 2.2 auto box problems
« Reply #1 on: 07 September 2012, 21:35:51 »
Easy first step is check fluid level - warm up, engine running, get car in air, but level, remove filler plug, ensure filled to this level.
Beyond that, I'd get the engine and gearbox codes read, and post them up here.
tal
« Reply #2 on: 08 September 2012, 17:39:18 »
Fluid was checked 300 miles ago and all was ok according to garage who serviced it. Have read about the throttle position sensor problem. Is this sensor something I can try cleaning or is it non serviceable? Still trying to find someone with a code reader but may just have to shell out at a local garage for them to plug it in. It's fines if you stop and restart the engine which is making me think its electrical rather than mechanical
« Reply #3 on: 08 September 2012, 18:05:25 »
Be a good idea to add your location then ;)
tal
« Reply #4 on: 09 September 2012, 19:11:41 »
Sorry. Location is Surrey. Cheers
pauls
  • By the sea minehead
    • Bmw x3
« Reply #5 on: 10 September 2012, 08:41:33 »
I would say kevin woods is the closest to you :y Send him a pm
tal
« Reply #6 on: 10 September 2012, 18:21:26 »
thanks mate will pm him :
