ETS Exhausts Review
Started by TheBoy, 09 September 2012, 18:32:26
You put on the centre sections (can you spot whats wrong? Clue is drives side...)
But look what happens at the back.... (yes I know my springs are shot  ::))
Spot the difference  ::)
Shit build as well, should have bought Eternal  :(
Possible it was damaged in transit? Other reviews seemed to imply they went straight up :-\ :-\
Can't comment on quality as I doubt anyone other that yourself and your assistant for the day have seen both ;)
SteveAvfc.
Quote from: TheBoy on 09 September 2012, 18:32:26
Shit.
Quite bought a cat from them once would not meet up at the manifold because it was to tight to the gearbox. Cheeky self-abusers said it was my bad fitting got it changed for a different style but no apologies.
grain.ben
haha, im in the picture there  :D , sorry to say it Tunnie, but shite as TB says, by looking at it thoughrouly this afternoon, we came to conclusion it was either damaged in transit or a manufaturing fault, which is what TB is going with  :P
grain.ben
God, just noticed, im going bald!  :o
jb
PRETTY SURE THESE ARE THE SAME UNITS SUPPLIED BT ETERNAL - HAVE A P STAMPED ON THE CLAMSHELL
Quote from: jb on 09 September 2012, 20:29:25
Heard you ok mate  ::)
YZ250
I initially thought the rear section was out of position but looking back at picture No.1 it appears that the right hand side front pipe is forcing the clam shell out of parallel.  :-\ Even where Ben is holding them together for comparison the clam shells are not level.
I assume they are being returned.  :-\
grain.ben
Quote from: YZ250 on 09 September 2012, 20:51:47
Pipe still miles out though  ;)
Murph
Strangely mine fit fine and I've had no problems!
YZ250
Quote from: grain.ben on 09 September 2012, 20:57:45
I agree it's not pretty.  :y Bit of a pain when you're under it ready to go.  :(
Passenger bank is ok, its driver side which is feked. Backbox is ok too, will call ETS tomorrow & see what they say.
Going to supply pictures as proof & hope they send out a replacement, then do what ever they want with the dud.
