Author Topic: help needed  (Read 2152 times)
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
help needed
« on: 09 September 2012, 19:39:58 »
hi all who may read this, i have a z22se engine and wondered if anyone had the cam chain locking tool available, i will pay p+p charges and also give willing person a drink for the loan, seems crazy the price for one to use it once, if this is in wrong place mods please move     many thanks   adey
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Re: help needed
« Reply #1 on: 09 September 2012, 20:08:29 »
The locking kit for the 4 pots aren't that expensive normally :-\
Re: help needed
« Reply #2 on: 09 September 2012, 20:23:19 »
A locking kit for a chain driven cam?  :-\ :-\ :-\
adey2
Re: help needed
« Reply #3 on: 09 September 2012, 20:26:34 »
60 quid for the cam one on the chain engine,just a piece of metal with two holes for locking cams is daylight robbery when all other engines are 20 quid, ive had to strip it down after a foriegn body found its way into no4 cyl, took both sets valves out, full gm head gasket set, genuine valves,also torx socket fell off extension bar when undoing bolts nr chain when withdrawing socket so all the chain cover needs gaskets too again genuine gm ordered so parts list adding up, also going to do the waterpump for good measure as the history on car is unknown, this also needs a locking tool to fit as fits into balance chain set up, i must be mad when a box of matches and gallon fuel so much cheaper
adey2
Re: help needed
« Reply #4 on: 09 September 2012, 20:30:54 »
Omegatoy
  • UK
Re: help needed
« Reply #5 on: 09 September 2012, 20:40:16 »
pop round to TB,s place and ask to borrow the electric door opener stay, its easily modded to look like that one,  ;D
should take about  an hour to make one from scratch!!
Re: help needed
« Reply #6 on: 09 September 2012, 20:41:04 »
2 x mole grips  ;)
