Creaking spring
Started by a2reed, 10 September 2012, 02:57:26
a2reed
My front right spring lets out a metallic "pop" sound as I turn the wheel ... also sometimes when going over speed bumps etc .... not of course the clunking you get with buggered wishbones ... listened very carefully definitely the spring making the noise ....anyone know what might be wrong?
Deuce
Sounds like the coil is broken, possibly.
a2reed
Thats what I thought and might explain the strange pulling going on ... could it have become unseated ????
If its always in the same place, check top strut bearing as well
henryd
Quote from: TheBoy on 10 September 2012, 09:37:18
If the spring is complete that's where I would be looking too :y
other rides
a2reed
What does the top strut bearing do and is it hard to get at?
Does it mean a new strut?
henryd
Quote from: a2reed on 10 September 2012, 12:12:18
it contains a bearing that allows your strut to swivel when you apply steering lock,problem is the bearings gets water and mud in it which makes it start to stick so when steering lock is applied you get a clonk as it lets go and starts to move :y
the top mount is a seperate part which is replaceable,not sure if the actual bearing is available on its own though :-\
other rides
a2reed
That sounds like my problem ... So if I replace the top mount two questions how much is a new one including bearing Approx and do I need to do them in pairs?
a2reed
Just seen the mounts Approx £30 and the bearing about the same on ebay..... would non oem be ok for this area or should it be OEM?
Quote from: a2reed on 10 September 2012, 03:59:43
How was the spring diagnosed? If drivers side check the steering box bolts the chassis are tight. :)
a2reed
I held the spring while someone turned the wheel and the noise and vibrations were definately from the spring but I will also check the steering bolts... as for the pulling and tyre wear I think I am over due for new wishbones.... but I would like to get all the right bits at one time
If spring broken it should be visually obvious ;)
Any creek or knock in the steering or suspension and the spring will amplify and vibrate.
If the spring is broken it might be the culprit but it's more likely something else is sticking the giving elsewhere. If you can feel a knock at the steering wheel it's reverberating through the whole system.
a2reed
I am going to replace the wishbones anyway (Lemforder????) so I will remove everything then ... I assume I will need spring compressors??
henryd
Quote from: a2reed on 11 September 2012, 13:57:19
Aye you will need them to do the top mount :y
other rides
