Author Topic: xenon bulbs  (Read 7151 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: xenon bulbs
« Reply #15 on: 12 September 2012, 08:23:23 »
what are the best bulbs to replace them with and how much should I pay? I know main dealers would charge over the odds
Re: xenon bulbs
« Reply #16 on: 12 September 2012, 08:30:52 »
I would stick to the cheapest phillips or osram you can find.
the illumination from the chinese ones on ebay is not as good as it should be, and often have incredibly short lives that can end in fire.
kcl
  • Finland
    • Volvo V60 D4 -14
Re: xenon bulbs
« Reply #17 on: 12 September 2012, 09:27:20 »
Has anyone ever got any electric shock from Xenon headlights? I doubt not... It is very similar precaution as for airbags. Never ever seen or heard anyone get hurt except the funny videos on youtube where people are fooling around with bags... Ok, it is possible to get hurt with airbags after a crash where bags were not deployed but in real life, during normal maintenance etc I'd say it is more likely you will get hurt from your tools than airbags or xenons  :-X
I_want_an_Omega
Re: xenon bulbs
« Reply #18 on: 12 September 2012, 09:37:51 »
+1  :y
I totally agree. I broke an Omega once and needed the steering wheel as the leather on mine was marked. I removed the airbag (carefully) and decided to set it off just to see what would happen.
I carefully connected it to a very long cable which went to a power supply. Switched it on and it went bang (very very loud). But - it needed a pair of wires connecting and a supply connecting to them.
Sensible precautions yes, obviously - but nothing OTT - all IMHO of course
Re: xenon bulbs
« Reply #19 on: 13 September 2012, 03:53:04 »
For the sake off three bolts, just remove the headlight unit :y you have to unplug it to remove it, so no electrocution issues :y Also change the sidelight, main beam and indicator bulbs whilst the unit is out, purely for ease of access :y
Removing the whole unit will take less time than faffing with trying to undo the torx bolts from the engine bay :y
Re: xenon bulbs
« Reply #20 on: 13 September 2012, 04:36:19 »
I also remove the units... Much easier :y
Just to comment on what someone else posted. I've seen an airbag go off unexpectedly when someone was working on the car and it made a hell of a mess of his nose :o The warnings are there for a reason ;) A 20kV shock from the ballast is enough to make itself known and can (potentially) kill. Just disconnect the battery and remove the units ;) not a hard job, just fiddly
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: xenon bulbs
« Reply #21 on: 13 September 2012, 11:48:33 »
and what omegas have xenon bulbs fitted ..is it just elites..
Re: xenon bulbs
« Reply #22 on: 13 September 2012, 12:07:58 »
cdx, elite, mv6 by default on facelift.
I_want_an_Omega
Re: xenon bulbs
« Reply #23 on: 13 September 2012, 19:03:18 »
No PFL have them.
All MFL MV6 Elite models - optional on some other models
Steve B
  • Leicestershire
Re: xenon bulbs
« Reply #24 on: 13 September 2012, 19:22:00 »
so are you saying all fl cd 2.2 have them 02 plate
Re: xenon bulbs
« Reply #25 on: 13 September 2012, 19:27:02 »
As a rule of thumb any car with headlight washers and no headlight range adjustment on the headlight switch has xenons fitted :y
So standard fitment on CDX, ELITE, MV6 F/L
« Last Edit: 13 September 2012, 19:28:38 by taxi al »
Re: xenon bulbs
« Reply #26 on: 13 September 2012, 19:28:11 »
not by default.
Steve B
  • Leicestershire
Re: xenon bulbs
« Reply #27 on: 13 September 2012, 19:29:45 »
not by default.
good cos they sound trouble
Re: xenon bulbs
« Reply #28 on: 13 September 2012, 19:36:44 »
not by default.
How so? The bulbs last alot longer and they give a much better light... :y
Page created in 0.017 seconds with 15 queries.
