Halfords budget cycle carrier review
Started by tunnie, 12 September 2012, 18:06:41
So I picked up a pair of bike carriers for £19.99 each, they attach to roof mounted bars.
Sadly I've not had a chance to use these in anger, as ETS c0cked up my exhaust for the 3.2  >:(
But tinkering around today, I fitted one of them to my 2.2. For the price, I'm quite impressed.
Here the carrier is mounted with my bike:
The support beam attaches well to the frame:
The front & rear wheels are strapped to the rack, there are U bolts which loop around the roof bars.
Once the bike is off, looks like you can re-use the straps to tie the support bracket down:
I know a few people have been posting recently about carriers, hope this is of help.  :y :y
Be aware that on some bikes with large diameter down tubes the clamps don't seem to fit that well, I back up the clamp system with a couple of small bungees to make sure the clamp and support bar cannot come off ..as the result at 60 mph would be ........  messy ??  :)
Quote from: Entwood on 12 September 2012, 18:17:15
Thats a good call, thanks  :y
The lower part of the frame on mine is quite thick, I've got spare bungee's - How do you ensure that bracket does not move? If you attach a bungee from bracket to roof bars, it would be pulling it down? Guess if its tight its pulling against that  :-\
r1
i dont think useing a bungee to tie it down is a very good idea myself as they are not very strong.
Quote from: r1 on 12 September 2012, 19:13:23
Bungee is NOT used to tie anything down .. it is used to ensure the clamp does not come off the down tube. I simply use a short bungee around both the clamp and down tube as on large diameter down tubes the clamp is a poor fit. A tie-wrap, piece of string or anything that stops the clamp slipping would do.
My bungee is simply in a sort of "figure of eight" ... outside of clamp, across under the down tube, over the down tube, down to the outside of the other side of the clamp. this both pulls the clamp together and pulls the tube "into" the clamp if that makes any sort of sense ....  I use a short bungee as it is very easy to fit and remove
mantahatch
This is something I could be interested in. I notice the big plastic nut is on the inside, does that make it hard to reach ? or could it be put on the other way round. I ask because of limited mobility at times when reaching up.
Quote from: Mantahatch on 13 September 2012, 07:39:34
Mine are a deal older than these, and not such "pretty" colours, but the handscrews can be repositioned either side with ease on mine :)
mantahatch
Quote from: Entwood on 13 September 2012, 10:13:49
Thank You  :)
Yeah you can take it out by looks of things, so can reverse it, not tried it though, as I can reach it. I think it might be better on inside as if you park in Tesco for 5 mins, less likely for someone passing to think its funny to un-do it!
mantahatch
Quote from: tunnie on 13 September 2012, 10:47:03
Ah, so does that mean it is not locking ?
Quote from: Mantahatch on 13 September 2012, 21:08:07
No locking, just tighten only. Can't see any way to lock them, unless you put on a D lock or something.
Varche
I still have and occasionally use my pair of these Halfords cycle carriers I bought in 1996.
They are good enough for the job but I still check them regularly on any journey.
