Author Topic: cam belt swap  (Read 3652 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
cam belt swap
« on: 15 September 2012, 20:28:52 »
 WELL  i have the elite running at last thanks to elite Pete  :y :y :y doing the cambelt swap . what a great chap;  only 235 pound to do the change' new water pump  and coolant as well [ parts included ] in the price ' he also got the timing perfect and sorted out the breather pipes . so its now running much better and im getting better fuel economy .  :)  And he also puts everything back were it should go with all clips fastened and  bolts  torque up correctly'     highly recommended  :y :y :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: cam belt swap
« Reply #1 on: 16 September 2012, 08:14:49 »
the boys on here are much better than your average grease monkey. ;)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: cam belt swap
« Reply #2 on: 16 September 2012, 15:43:25 »
I would be interested to know how it can be done for that money. Genuine question.  :y The regular guys obviously have a cheaper supplier as I can't beat that doing it myself using Trade Club as supplier. Obvious answer is to shop around for reputable parts I suppose.
I assume either Gates or ContiTech as cambelt kit supplier.  :-\
Trade Club for Cambelt kit, Water pump, Auxiliary belt and Anti-freeze comes to around £216 + vat so you got a very good deal as far as I can see.  :y
Doing it myself when I could sit on my arse and have it done cheaper is mildly annoying.  ;) ;D ;D
Should this be in General Car Chat.  :-\
Re: cam belt swap
« Reply #3 on: 16 September 2012, 15:44:31 »
Yep Contitech parts were used :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: cam belt swap
« Reply #4 on: 16 September 2012, 22:13:56 »
It's easily done by sourcing the parts from an economical supplier.
I paid £110 delivered, last year for a continental belt kit and an aftermarket waterpump(don't know the source, just took it out of the box and bolted it on). Buying this sort of part from Vauxhall is just extravagant, as none of it was only available from them. As your price of 2.5 times as much proves.
The labour rate is easily explained by lower overheads. After all, main dealers make their money from servicing and repairs rather than actually selling cars. Those lovely showrooms have to paid for somehow.
symes
  • oxford
    • R reg 940 volvo
Re: cam belt swap
« Reply #5 on: 16 September 2012, 22:18:52 »
funny you mention parts-theres a company near me that puts the same parts inboxs printed ford,motaquip etc so when buying genuine? is it?? :o
YZ250
Re: cam belt swap
« Reply #6 on: 16 September 2012, 22:36:17 »
Easy enough to get a ContiTech cambelt kit near me but I'm not finding it as easy to source a Gates kit.  :-\
I don't mind saving a bit on the water pump but I would have preferred a Gates cambelt, if only because I've used them on previous cars. Trade Club want £111.81 + vat for cambelt kit whereas BuyPartsBy want £68.50 + vat I assume, for a Conti belt kit.
Decisions decisions.  :-\
Edited by me : I meant BuyPartsBy. Euro Car Parts want £127 for a cambelt kit.
« Last Edit: 16 September 2012, 22:51:36 by YZ250 »
ted_one
Re: cam belt swap
« Reply #7 on: 16 September 2012, 22:45:08 »
I can only agree,I've just ordered a cambelt kit,aux belt,water pump,4 plugs,air,oil,cabin fuel filters,2x4.5ltrs semi synthetic,ignition coil and leads..total cost including delivery £201.00 all from Buypartsby. obviously this for a PFL 2.0 ltr but I would certainly use them for my 3.0 and 3.2 parts as well. :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: cam belt swap
« Reply #8 on: 16 September 2012, 23:04:58 »
Top man Pete.  :y :y :y
Re: cam belt swap
« Reply #9 on: 17 September 2012, 08:52:28 »
Indeed - there are some parts that are only dealer only parts - cam cover gaskets spring immediately to mind.
There are other parts that I do go to a dealer, because the GM part is a better part, but where a pattern would suffice - air filters being a classic example.
There are other parts where I get parts from a dealer based on price and (no) hassle factor, and the part is as good as any other - oil, plugs etc
And there are parts where the GM price is ridiculous, or the quality has dropped off the GM part, so I go out in the pattern market.
One of the areas where OOF can help is to recommend which categories things fall into :)
YZ250
Re: cam belt swap
« Reply #10 on: 17 September 2012, 10:04:59 »
And there are parts where the GM price is ridiculous.................
So, as I'm soon to purchase a cambelt kit, where does OOF stand on them. I've had a look through previous threads regarding OE/OEM parts but I must admit that I nearly always buy from a Vauxhall dealer anyway. For something this important I wouldn't even consider un-branded so that doesn't come in to this equation.
If I go GM cambelt kit, I'll get supplied a Gates kit anyway, but if I go BuyPartsby I'll end up with a ContiTech kit. I won't be looking any further than those two suppliers.
I suppose what I'm asking is, what is the OOF preference, Gates (sourced from motor factor) or ContiTech, seeing as they both appear to be well respected. Previous threads imply that either of these are decent so it seems to come down to the price difference.  :-\
Re: cam belt swap
« Reply #11 on: 17 September 2012, 11:47:21 »
Gates, Contitech & SKF kits are all equivalent to genuine, IMHO.
All have SKF bearings, SKF and Gates have gates belts. Can't remember if the Conti one is their own belt or a gates one but I would buy whichever of these you can get cheapest.
YZ250
Re: cam belt swap
« Reply #12 on: 17 September 2012, 12:16:52 »
Thanks for that Kevin.  :y
Swordfish
Apologies for the thread hijack.  :-[ I should have started a new thread as it has deviated from you praising Pete's work.  :-[
Glad you are pleased with the work done by Elite Pete and it was a good price.  :y
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Re: cam belt swap
« Reply #13 on: 17 September 2012, 23:17:36 »
Excellent choice Swordfish/scorpian :y(injoke between me and Pete!)
Jon
Re: cam belt swap
« Reply #14 on: 18 September 2012, 15:29:23 »
Have always got the Contitech kits from Buypartsby - cheapest, fast delivery and no issues once fitted :y
Used to use genuine Vx water pumps until prices got silly - last one I got was a QH - reasonably priced and quality looked ok.
