Overdue a trip to WIM ?
Started by albitz, 16 September 2012, 21:17:30
This is the n/s/f tyre on my latest breaker.
twiglet
Was that the one that was in the boot?  No wonder the spare was on!  :o
Yep. :y He did seem a bit flustered when you asked where the other alloy was. ::) ;D
I hope you dont call this a tyre ;D
Loads of life left in that yet! ;D ;D ;D ;)
Its disgraceful that people don't notice that kind of wear, or they do, but ignore it  ???
Then again, motherT failed to spot a rear shock was totally failed. Not just worn, but catastrophic failure.  ::)
Quote from: PhilRich on 16 September 2012, 22:08:16
I have a can of black spray in the shed.Jobs a goodun. :y ;D
Quote from: Albitz on 16 September 2012, 22:58:06
first apply some epoxy  ;D
Pah, if you are going to bodge it. Bodge it. Gaffer tape  :D  ;D
Do they do gaffer tape in black ? :) :D
Quote from: Albitz on 16 September 2012, 23:14:44
No, but you can Epoxy it then spray it black! ;D ;)
A member had similar on both fronts, was quite upset when I noticed, as only been on 3 months. He had had it 4 wheel aligned on fitting - another example of why you shouldn't waste money on anything other than a full geo check.
