Author Topic: Another Power Sounder  (Read 1511 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
« on: 19 September 2012, 16:04:10 »
Removed the Power Sounder today,there where no Chirps,no funny sounds and no false alarms ???
I only did for piece of mind,going by all the recent posts.But as you can see from the pics that PCB+ batteries look new to me.[imhttp://i1252.photobucket.com/albums/hh578/johnhmp/Omega%20005_zps0c9e6777.jpgg][/img]
Re: Another Power Sounder
« Reply #1 on: 19 September 2012, 16:07:13 »
yup, looks in quite good nick :y  must just be dead
tooleater
« Reply #2 on: 19 September 2012, 16:20:17 »
Nope working perfectly,may be last owner stuck a new one in there, I had some more pics but posting them is a bit hit and miss computers and me  :-[ :-[ :-[
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #3 on: 19 September 2012, 17:48:55 »
The way I see it is that they put these powersounders into LOT's of GM vehicles and you just don't see Astra's, Vectra's, Omega's etc. on fire everywhere.
...may be last owner stuck a new one in there...
If you look at the picture 'Jimbob' posted up you can just make out a round symbol with an arrow in the centre, it's on the lower left of the rear case, that will tell you when the item was made.
« Reply #4 on: 19 September 2012, 19:08:43 »
It will be made just prior to the car being built. It's not possible to tell if the circuitry is damaged from that pic, but any slight battery acid will leak from the ends of the battery from under that green plastic shrink wrap.
There may be slight leakage, there may not. But provided the circuit board is ok, then that's in a perfect state to solder in new battery's and re fit.  Better to catch it earlier than when it's too late. Is they WILL leak eventually. :y
« Reply #5 on: 19 September 2012, 19:36:34 »
I've only seen that style fitted to the later facelift models, so it might have been replaced already. As said, there'll be a date on the back of the case.
