Author Topic: brake fluid  (Read 1873 times)
big mel
  • Oldham Lancs
  • ex trucker' GB. USA. CONTINENT& GB
    • Omega 2ltr gls 2000frpp
    • big melL
brake fluid
« on: 20 September 2012, 16:07:49 »
Hi all. has it got to gm brake fluid for my mig or is there a good alternative? i'm planing to change mine, I believe 1ltr will do the job. tia mel.
THE TRUCKERS MOTTO. keep the shiny side up & the greasy side down. the bugs off your glass &  the bears off your ass.
Re: brake fluid
« Reply #1 on: 20 September 2012, 20:47:32 »
Any brake fluid to the GM specification ok  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: brake fluid
« Reply #2 on: 20 September 2012, 20:54:04 »
dot 4 mate. Not sure if brake fluid is on tc or not. I'd personally buy more than one litre just in case
RIP Paul Lovejoy
Re: brake fluid
« Reply #3 on: 20 September 2012, 20:58:21 »
DOT 4 or DOT 5.1 (not DOT 5!) - Motul RBF600 is good stuff, just depends how much you want to spend on it really..
Re: brake fluid
« Reply #4 on: 20 September 2012, 21:02:13 »
Yep DOT5 is synthetic Silicone Brake Fluid - not compatible with the rubber seals in Omegas
Webby the Bear
  • Northampton
Re: brake fluid
« Reply #5 on: 20 September 2012, 21:30:16 »
and make sure you keep an eye on the level as yo  do it. You dont want to run the master cylinder dry :-)
RIP Paul Lovejoy
big mel
  • Oldham Lancs
    • big melL
Re: brake fluid
« Reply #6 on: 21 September 2012, 16:13:36 »
Thanks for the info everyone. mel.
Re: brake fluid
« Reply #7 on: 22 September 2012, 09:40:38 »
Any DOT4 is suitable for the Omega. If you use it for track days, or really hammer it hard, DOT5.1 may be beneficial, though is expensive normally.
Personally I buy a couple of the smallest 250ml ones on TC, rather than a larger one, as once its opened, its pretty much junk.
