WANTED- Radiator for 3.2 Auto!!
Started by Stallion, 20 September 2012, 18:34:44
Stallion
got my fingers crossed and putting up a wanted ad, need a radiator for a 3.2 auto? can collect if local and already of the vehicle.
also can anybody advise if the radiator only has a numeric part number or has letters too please.. Sam :y
Stallion
forgot to add vehicle does have A/C too thanks..
I have one from a 3.0 auto here Stallion.If someone can confirm thats the same (I think it is) I can sell you that one. :y
Stallion
was just about to bother you  ;D i dont even know what the actual part number is for it either to compare?? :-\
twiglet
Albs, just make sure you breaker has a seperate autobox oil cooler, and the aux electric water pump attached to the rad fan cowling.  If it does, the rad will fit Sam's car perfectly.  :y
It doesnt have the seperate cooler,but iirc the 2.6/3.2 rads still have the inbuilt cooler,they just dont use it. ;)
twiglet
You may well be right.  I'd need to have a look at mine in daylight to be sure.  :-\
Dont they have torches in Naarfik ?  :P ;D ;D
Quote from: Albitz on 20 September 2012, 19:38:59
Only the early ones ;)
twiglet
Quote from: Albitz on 20 September 2012, 20:18:46
Yeah, but only solar powered ones!  :D
Since you asked so nicely, I've just been and had a look...  ::)
I can't see any blanks where the pipes would connect to mine.  :-\  That's not to say your rad won't be ok for Sam, but it might have slightly less capacity that a proper 3.2 one.
In fact, IIRC I helped P6UL K out of a muddle with a rad from a MFL V6 with built-in intercooler for his 3.2 manual.  :y
Quote from: twiglet on 20 September 2012, 20:35:28
You won`t :)
My 02 3.2 breaker had red plastic blanking caps for the transmission cooler. :-\
Well,thats made everything as clear as mud. ;D ;D
Quote from: Albitz on 20 September 2012, 20:40:07
Could well have been a replacement. Genuine rads for late model 2.6/3.2 don`t have the in-built coolers
twiglet
What year is your car Sam?  IIRC it's not a really late 3.2.  So following Rob's advice, you may well find that Albs' rad will be a direct replacement.  :y
Yep.Best Sam has a look or posts a pic of the o/s of the rad.I will also have a look for a part number on mine. :y
