Another MOT pass.
Started by albitz, 21 September 2012, 14:43:34
My Omega had its MOT this morning.Failed on number plate lamp needing a bulb which was rectified there & then,so got a years ticket. Had an advisory on diff weeping oil onto the exhaust,must have a look at that sometime,or at least add it to the list. :)
b4ndit
Quote from: Albitz on 21 September 2012, 14:43:34
Easier to swap one off the breaker than faff about with pinion seal ;)
Good result with MOT.....................................if you`d have checked all your lights ::) ::)
Snap  ;) Good news well done  :y
Quote from: RobG on 21 September 2012, 14:49:50
Had the same thought Rob,as long as its the same ratio and not leaking too. :y
