Author Topic: Coolant transfer pipe  (Read 3596 times)
Manual Elite V6
  • Swansea
  • Mechanic and MOT tester at a Jaguar specialist.
    • 1992 Cavalier GSi
« on: 24 September 2012, 19:56:12 »
I'm in the process of changing my o/s exhaust manifold gasket and when I removed the coolant transfer pipe I couldn't see the o-ring and it hasn't dropped down, there looks to be one inside the pipe but it doesn't fell like there is one there, my question is does the o-ring sit inside a groove in the pipe or is it just placed there?
Thanks
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
Re: Coolant transfer pipe
« Reply #1 on: 24 September 2012, 20:04:56 »
Thanks
I thought there were two O rings in the transfer pipe  :-\ :-\ Anyhow if you've got that far, replace them ..... they go hard with age.
martin42
« Reply #2 on: 24 September 2012, 20:06:40 »
there is 2 o rings  :y
« Reply #3 on: 24 September 2012, 20:10:26 »
I suspect the OP is referring to the pipe which goes around the o/s of the engine to the rear of the block rather than the one from the stat.
« Reply #4 on: 24 September 2012, 20:12:32 »
Ah!  ::)
Manual Elite V6
  • Swansea
    • 1992 Cavalier GSi
« Reply #5 on: 24 September 2012, 20:22:48 »
That is correct, I am replacing the o-ring, will have it tomorrow, however when removing the pipe I did not see or feel it fall and cannot see it under the car anywhere, there looks to be a seal recessed in the pipe but it just feels solid, I just need to know it this is the seal before I try hooking it out.
Thanks.
1992 Cavalier GSi
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #6 on: 24 September 2012, 20:39:20 »
Yes, the "o" ring is in a slot on the pipe. When refitting with a new "o" ring use a smear of gasket cement or grease to hold it in place, as they can easily move while re-fitting and doing up the pipe's easy to get to bar-steward bolts.  :-[ :-X
Manual Elite V6
  • Swansea
    • 1992 Cavalier GSi
« Reply #7 on: 24 September 2012, 21:25:34 »
Thankyou, also does anyone know a good source for the dowty washers for the coolant bridge?
Thanks.
1992 Cavalier GSi
amba
  • Medway towns
    • German V6
« Reply #8 on: 24 September 2012, 22:29:42 »
As stated 1 "0" ring seal sits into the recess on the coolant transfer pipe...its a VX part only and also wise getting the bridge dowty washers there too.
Manual Elite V6
  • Swansea
    • 1992 Cavalier GSi
« Reply #9 on: 24 September 2012, 22:34:05 »
Thanks you, does anyone have the part number for these washers?
Thanks.
1992 Cavalier GSi
amba
  • Medway towns
    • German V6
« Reply #10 on: 25 September 2012, 06:57:00 »
Coolant pipe O-ring                 9128362
Bridge Dowty washers             12992647
New thermostat transfer pipe will come with the 2 rubber "0" ring seals
« Reply #11 on: 25 September 2012, 10:08:23 »
As Rod says. I was that man, there's nothing worse than getting it all back together to hear the tinkle tinkle of running water when your refilling ::)
I use cam cover sealant whenever I do them now :y
« Reply #12 on: 25 September 2012, 11:01:59 »
Ah yes, I seem to recall that at the Telford cambelt meeting.
Didn't we do a fast fix the next morning?
« Reply #13 on: 25 September 2012, 11:08:26 »
It was done the same day :y
Don't think I could have worked the day after the Saturday night ::)
« Reply #14 on: 25 September 2012, 11:31:09 »
Fresh air in the premises was in short supply, for a start, if memory serves. ;D
We really ought to organise another meet with the added comedy backdrop of wedding day inbred family feuds, punch ups, pint glasses being chucked and a clueless Police presence. Not to mention Hotel21's "under the table" malt-based product distribution as an alternative to the lager. :y
