Author Topic: lsd identification  (Read 5416 times)
bellers
lsd identification
« on: 25 September 2012, 23:44:58 »
looking to get a definite answer to this. i dont have a sticker on my diff (well cant find one) so i jacked up the rear end and spun the prop and both wheels spun in same direction. then i spun one wheel and the other spun the same way.
now going by when i had a sierra that was how to identify an lsd, going buy this method it means ive a lsd in my car.
would i be right saying it is an lsd?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: lsd identification
« Reply #1 on: 25 September 2012, 23:55:15 »
Best way to be certain is to remove the cover plate on the diff and see, or perhaps see how it behaves when you drive 'spiritedly'.
« Reply #2 on: 25 September 2012, 23:58:11 »
looking to get a definite answer to this.  .....
As above, or remove a drive shaft from the diff & look down the hole. If there's a cross, you've a LSD, if just one drive 'slot' then you've not.  :y
JimE
« Reply #3 on: 26 September 2012, 00:01:53 »
Which models had lsd  fitted as standard?
« Reply #4 on: 26 September 2012, 00:02:32 »
Any juddering when pulling away on full lock?
« Reply #5 on: 26 September 2012, 00:03:30 »
none!  ;) ;) It was an option ..... even on white Plod cars.  :y
bellers
« Reply #6 on: 26 September 2012, 00:48:03 »
thanks for the quick replies  :)
i know its hard to tell buy driving spiritedly cause when id my old omega i could of sworn there was an lsd in it but when the diff decided it had enough i found out it wasnt when i removed it.
is there enough room to remove the cover plate in the car without having to drop the diff or remove shafts?
Sehen
  • Norway, up north...
    • Omega???
« Reply #7 on: 26 September 2012, 06:44:04 »
+1 about the taking out the driveshaft to have a look inside. The best way to identify :)
In Norway, all Omega B's that came trough the official importer have the lsd as standard ;)
But it was wery scearing when I bought my first 4 pot, the 2001 2,2...it has no TC  :-\
With the automatic and wet ice, I learned quickly that the use of cruisecontrole is a no no in the winter  :D
98 Omega 2,5V6 Man. Homemade from a 2,0Auto
bellers
« Reply #8 on: 26 September 2012, 08:27:00 »
Sehen what happened with cc in winter? A bit uncontrolable?
Do both ends of the driveshaft have splined shafts? Are the hard to take out with diff still in place? Anything else have to come of? Hub or anything?
« Reply #9 on: 26 September 2012, 08:58:42 »
What model Omega do you have?
bellers
« Reply #10 on: 26 September 2012, 10:44:44 »
Ive a 99 3.0 elite. They guy i bought it of said the was an lsd fitted. It does leave 11s on the road and it does do circles. Just will spin one wheels sometimes. Was going to change oil in it and see what happens but would like to know if its and lsd before i buy the oil
« Reply #11 on: 26 September 2012, 10:51:43 »
Auto or manual?
Its not a blue Elite estate is it ::)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #12 on: 26 September 2012, 11:51:03 »
There is some sort of "Scandinavia-package" which included at least LSD, bigger battery, DRL relay, dunno what else. That's why most of the cars also here have lsd fitted, although have seen/heard a few being without lsd  :-\
bellers
« Reply #13 on: 26 September 2012, 20:22:55 »
Auto or manual?
It started its life as an auto now a manual. Its a saloon
Sehen
    • Omega???
« Reply #14 on: 27 September 2012, 00:48:43 »
Kind of uncontrolable yes.... when the cc want's to maintain the speed uphill, it sometimes makes a kickdown, and with a LSD on the car on icy roads, it suddenly goes sideways. With oncomming traffic... you've got the picture?
Really not an issue on the V6, as it have the TC, and that's what I'm used with  :D
