Author Topic: cutting out  (Read 3813 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
cutting out
« on: 27 September 2012, 06:16:42 »
Hi  i have a 3.0 elite x reg . the problem is that every 20 to 30 mile it starts to miss and cuts out . if you turn off and leave for 5 mins it starts fine again .or if you just keep restarting it it starts and cuts out again . its had a new icv and elite pete has checked for air leaks
Re: cutting out
« Reply #1 on: 27 September 2012, 09:38:27 »
Releasing the fuel filler cap seemed to make a difference or it didn't cut out when I undid the cap every 5 minutes
Re: cutting out
« Reply #2 on: 27 September 2012, 09:57:47 »
Blocked fuel tank breather ? or the usual suspects - crank sensor,or dispack ?
swordfish
  • manchester
Re: cutting out
« Reply #3 on: 27 September 2012, 17:09:42 »
ok .first i will try it without the fuel cap on see what happens cheers . carl :y
swordfish
  • manchester
Re: cutting out
« Reply #4 on: 30 September 2012, 19:58:34 »
 OK . no look with removing the fuel cap it still does it ??? . but i was on the motorway today and it started again; but it would not cut out because i had constant revs .but it was missing bad so i pulled off and it cut out .tried to restart it started but with a puff of smoke and you could smell the cats real bad [ rotten egg smell] so i think the cats got real hot because of the timing  with the  coil packs playing up . it then drove like normal again all the way home so i think it could well be the coil packs  what do you think  cheers  :y carl
Re: cutting out
« Reply #5 on: 30 September 2012, 20:54:16 »
Check for fault codes (pedal trick),pull plug leads and check for oil in the plug wells. ;)
swordfish
  • manchester
Re: cutting out
« Reply #6 on: 01 October 2012, 06:24:54 »
its a 2000 3.0 l elite. :-\ i thought that was the paper clip test
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
Re: cutting out
« Reply #7 on: 01 October 2012, 06:48:36 »
I had similar issues with my 2.0 16v. It was very annoying and a worry on major roads. Turned out to be the crank sensor. The wires at the sensor end had become bare and were touching each other giving confusing signals to the ecu. Replaced and car working well again. You need to get the codes.
Re: cutting out
« Reply #8 on: 01 October 2012, 09:15:29 »
Yup, do a paperclip test :y
swordfish
  • manchester
Re: cutting out
« Reply #9 on: 03 October 2012, 09:41:00 »
 OK done paper clip test. results
                                        74 [mass air flow sensor voltage high]
                                        89 [02 sensor 2 open circuit ]
                                        13 [ 02 sensor 1 open circuit]
                                        31 [ no engine rpm signal]    engine was not running during test
kcl
  • Finland
    • Volvo V60 D4 -14
Re: cutting out
« Reply #10 on: 03 October 2012, 10:48:14 »
My money goes on MAF  :y
swordfish
  • manchester
Re: cutting out
« Reply #11 on: 03 October 2012, 15:47:24 »
whats  MAF   :-\
Re: cutting out
« Reply #12 on: 03 October 2012, 17:41:52 »
Mass Air Flow sensor
swordfish
  • manchester
Re: cutting out
« Reply #13 on: 05 October 2012, 06:20:37 »
 thanks .anybody got one for sale
Re: cutting out
« Reply #14 on: 05 October 2012, 06:25:36 »
Yes. Will send you a PM. I will try and find a pic of one to send you,then try unplugging the electrical plug to yours.If yours is faulty,the car may run better with it unplugged as the ECU will use a default setting rather than the faulty signal froma damaged MAF. This would confirm yours is faulty,although the fault code has probably already done that tbh.  :y
« Last Edit: 05 October 2012, 06:37:05 by Albitz »
