Author Topic: ATF Decision???  (Read 4739 times)
a2reed
  • Battersea London
ATF Decision???
« on: 27 September 2012, 10:06:43 »
Which ATF should I buy to renew my autobox fluid???
I have read on this site Dexron VI and also Fuchs and also Dexron 3
Confused???...can anyone help please???????????
Also how much??
Re: ATF Decision???
« Reply #1 on: 27 September 2012, 10:19:45 »
Dex 3. While all Dexron is said to be back compatatible. I wouldn't introduce unknowns personally. 3 is proven.
ESP given the the tis updates on pas Dex 2, where 3 was used, and the pipes leaked. So pas was downgraded to two again.
a2reed
  • Battersea London
Re: ATF Decision???
« Reply #2 on: 27 September 2012, 10:24:11 »
Is it worth getting from trade club... and how much?
Re: ATF Decision???
« Reply #3 on: 27 September 2012, 10:27:58 »
On which Dex 3. All dexron oil is supposed to match a certain grade. 3 in this case, so all Dexron 3 should be the same. However I can't bring my self to use that coma shite in my car.
Fuchs Titan range for Dex 3 is usually generally recomended on oof. Cirtainly was recomended to me anyway.
Trouble is coma is freely available, and Fuchs is very difficult to find locally IME.
amba
  • Medway towns
    • German V6
Re: ATF Decision???
« Reply #4 on: 27 September 2012, 10:28:11 »
Reliable source is Opie as listed in the For Sale section if you want Fuchs or similar.
Most factors sell cheaper brands,but most members use Titan DexIII.
Re: ATF Decision???
« Reply #5 on: 27 September 2012, 10:29:20 »
Not on tc.
Dealer is very expensive for Dex iirc.
Try a factors.
Re: ATF Decision???
« Reply #6 on: 27 September 2012, 10:31:28 »
And IME while Opie are good at claiming to offer great deals, this is not usually the case "IME"
There is little they don't stock though.
a2reed
  • Battersea London
Re: ATF Decision???
« Reply #7 on: 27 September 2012, 11:10:57 »
Is that Fuchs titan 3 longlife 5-30 oil ????
Re: ATF Decision???
« Reply #8 on: 27 September 2012, 11:23:42 »
NO! That's an engine oil and will knacker an automatic gearbox in short order.
What you're looking for is Fuchs Titan ATF 4000.
http://www.fuchslubricants.com/index.php?calling=products&sub=pgear&pcategory=category_39&prod=product_39_4
D
  • SE London
    • 03 3.2 Elite
Re: ATF Decision???
« Reply #9 on: 27 September 2012, 12:16:33 »
Why do you call it so? All Dex 3 should match a specification provided by GM. Is it just a brand image thing?
Unless you can prove Comma is poor in performance or gives trouble in use, it like saying I cant bring myself to use the ASDA paracetamol. I only use Anadin/other branded paracetamol. In the latter case at least the only difference being more revenue to the Anadin manufacturer and no real performance benefit.
Re: ATF Decision???
« Reply #10 on: 27 September 2012, 20:44:54 »
Comma Dex 3 ok for Vx autoboxes :y  It is to the Dex 3 spec.
Later Dex specs are backwards compatible with Dex3 :y  Includes Dex 6 :y
Re: ATF Decision???
« Reply #11 on: 27 September 2012, 21:18:06 »
Once again D your picking an argument on something we actually agree on. Read it as you like, but I agree fully with what your saying in principle.
However, its my car, and i will install whatever product is I see fit. ;)
Hopefully between us we will help the op to make his own mind up, and he can install as he sees fit.
As said, again, all Dexron 3 should meet the exact same spec. You could argue that the cheaper stuff is inferior or fairly priced, or you could argue that the expensive stuff is over priced or somehow better quality...
Personally, for the sake of a few quid, like tyres, I'd rather play safe. But that's MY choice. :)
Re: ATF Decision???
« Reply #12 on: 27 September 2012, 21:26:48 »
Regards back compatible, yes that's true according to GM.
However what do we think regarding the Dex 2 pas issue? Where tis specifies that Dex 3 is NOT used, due to 3 causing leaking pas pipes?
Tis may be wrong, miss informed entry, some other anomoly caused the leak, whatever.
Or it may be correct. Play safe IMO.
Presumably the price rises with the Dex number too?
Re: ATF Decision???
« Reply #13 on: 27 September 2012, 21:56:46 »
Having had Titan 4000 and Comma in the same car, I reckon the Titan 4000 gave a smoother change.  Possibly placebo.  But as similarly priced, although not as conveniently available, I know what I'd shove in.
Not all oils are the same, be it engine oil or ATF.  Castrol Magnatec meets the spec for my engine, but I think most members know I wouldn't even let it go in the lawnmower, let alone my cars.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: ATF Decision???
« Reply #14 on: 27 September 2012, 22:03:10 »
i sold you the mower last week....its a electric flymog ;D ;D ;D ;D
Page created in 0.066 seconds with 16 queries.
