Author Topic: Stag LPG kit help  (Read 2103 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Stag LPG kit help
« on: 27 September 2012, 12:39:16 »
This is one for the LPG experts.
The Stag kits we got through Teilo; does anyone know what is the max power rating for the vaporiser and injectors from that kit?
I am looking at transplanting the kit in to a new car and I am stuck between 2.  A 1997 XJR (straight 6) or an S-Type 3.0.  I kow the kit will handle the S-Type but the chance to own a proper Jag with the 6 pots in-line is very tempting.
Re: Stag LPG kit help
« Reply #1 on: 27 September 2012, 12:46:11 »
I think he's supplied a couple of vaporisers over the years, so it probably depends which one you've got?
The KME Gold is rated to 240kW (~320bhp) if that's the one you've got..
Gaffers
« Reply #2 on: 27 September 2012, 12:54:06 »
I think it's the most recent one he did which has the two outlets for gas.
The XJR is rated at 322hp....that's borderline to say the least....unless I set it to switch to petrol above 4000k?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 27 September 2012, 13:31:14 »
That sounds like the gold one to me.
Might be better to use 2 smaller (silver) vapourisers and run 3 injectors off each  :y
If you drive like me you will spend most of the time above 4000 rpm when playing anyway so defeats the object imo  ;D
« Reply #4 on: 27 September 2012, 13:33:16 »
Guessing you've got the new injectors as well?
(Actually, of course you have. I remember the idle was a bit pants due to the jets being too big)
On the basis that they will happily run a 3.2 with (relatively) small jets drilled, I'd say there's a good chance that they'll be OK.
You will probably struggle with a multivalve tank. Suck it and see, I guess.
Not sure the 3.0 would be a great engine to LPG. IIRC it's essentially a Ford Duratec 30 and a lot of Fords of that era had soft valves. Bit of homework required there. That's only 230 / 240BHP, IIRC so not much more than a 3.2.
Gaffers
« Reply #5 on: 27 September 2012, 13:34:59 »
Maybe, I will give it a go with the gold....It cant hurt to try.  I can always change later  :y
Only when teaching boy racers and BMW/Audi drivers a lesson  ::)
Gaffers
« Reply #6 on: 27 September 2012, 13:37:34 »
Even more reason to go for the XJR, especially coming from Mr KW  :y
P.S. I am home in a couple of weeks.  Fancy helping me drink make a brew?  I have a recipe in mind and I will be calling it the "Thank F&*% I'm home beer" :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 27 September 2012, 13:50:50 »
Just had a thought, if you did fit 2 vapourisers how would you set up the gas pressure ?
2 pressure & temp sensors ?
How would they be wired into the stag loom ?
Sorry for the thread drift, just thought about it and its doing my head in already  ::)  :-[
Gaffers
« Reply #8 on: 27 September 2012, 13:57:17 »
run the signal from one sensor in to both vaps :y
Seen it done on the lpgforums
« Reply #9 on: 27 September 2012, 14:09:07 »
I would use a single sensor and tee the pressure reference to it from both "banks" of injectors. That way it sees the average of the two.
Then, you can clamp one hose into the "tee", adjust the first vapouriser, then clamp the other side, and adjust the other vapouriser so they are tracking the same pressure.
You could fit a larger "balance pipe" between them, of course, but then one vapouriser would probably be working harder than the other except when engine load is quite high, depending on minute pressure differences between them.
Each engine bank has its' own lambda loop, generally, so it should correct for any slight difference in fuelling. Not sure if that's true of the management on the straight 6, though?
« Reply #10 on: 27 September 2012, 14:09:51 »
Oh, and yes, of course, to the home brew. Just name the time. :y
« Reply #11 on: 27 September 2012, 14:26:29 »
Not got time at the moment, but there's a diagram from Stag for twin Vap setups. It needs a balance pipe ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #12 on: 27 September 2012, 15:00:48 »
Cheers for that  :y
Just been nosey like  ;D
« Reply #13 on: 27 September 2012, 15:03:37 »
Here you go...
Info is in this thread:
http://lpgforum.co.uk/viewtopic.php?f=33&t=11535
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #14 on: 27 September 2012, 15:12:49 »
Gotcha  :y
I'll go and invade somebody elses topic now  ;D
Page created in 0.018 seconds with 14 queries.
